Global Variables disappear!
Hello Again!
This is my new problem:
I've A public variable in Vba : A = 1
If I call a visual lisp routine, when it come back to Vba , My variable A is
resetted!
Is it normal to lose the variables after a Visual lisp call?
Thank you!
Pivanti Marco
No, it is not normal. I suspect you have declared your variable with the
wrong scope. Perhaps you can post some code.
Get free software and more at http://www2.stonemedia.com/~franko
"Maverick" wrote in message
news:8745f1$a397@adesknews2.autodesk.com...
> Hello Again!
is
> resetted!
> Thank you!
> Pivanti Marco
Ok: This is some code:
Public Layer_Terreno As AcadLayer
Public Layer_Sostegni As AcadLayer
Public Layer_Altro As AcadLayer
Public Layer_Vincoli As AcadLayer
Public Layer_Franco As AcadLayer
Public Layer_Righello As AcadLayer
Public PI As Double
Public Hatch_Solido As AcadHatch
Public FrontView As AcadViewport
Public TopView As AcadViewport
Public Fondamentale As Double
Public KX As Single
Public KY As Single
Public isFile as boolean
Public actPath as string
Private Sub AcadDocument_Activate()
actPath = "m:\marco\enel3d"
KX = 1
KZ = 1
IsFile = False
ThisDrawing.SetVariable "CURSORSIZE", 100
PI = 4 * Atn(1)
Set Hatch_Solido = ThisDrawing.ModelSpace.AddHatch _
(acHatchPatternTypePreDefined, "ANSI31", True)
Set Layer_Terreno = ThisDrawing.Layers.Add("Terreno")
Layer_Terreno.Color = acGreen
Set Layer_Sostegni = ThisDrawing.Layers.Add("Sostegni")
Layer_Sostegni.Color = acWhite
Set Layer_Vincoli = ThisDrawing.Layers.Add("Vincoli")
Layer_Vincoli.Color = acRed
Set Layer_Altro = ThisDrawing.Layers.Add("Altro")
Layer_Altro.Color = acYellow
Set Layer_Franco = ThisDrawing.Layers.Add("Franco")
Layer_Franco.Color = acBlue
Set Layer_Righello = ThisDrawing.Layers.Add("Righello")
Layer_Righello.Color = acGreen
end sub
This routine, set my variables when the acad is start.
subsequently, from the menù the user click on this routine:
sub Mmodifica()
frm_Modifica_Sostegno.show ' It's a Form
end sub
The form called have a button that call a visual lisp routine:
(defun c:disdima (/)
(... this function draw a matematical function tracking the mouse ...)
(command "_-vbarun")
(command "Getcoord")
When the lisp function ends call a Vba routine that read the coordinates
from a file... but when I'm return in VBA the global variables are all
disappeard (This thing also happen when an error occur and I click on the
end button!).
Have you need of other information?
I don't know how A2K is affected, but in R14 you need to close the IDE
window while running a procedure or you can lose global variables.
Hope this helps,
- Adam
I must confess Maverick, I am confused. How do you expect to run a LISP
routine from a VBA form? Also, when you say your globals have disappeared,
are yousaying your layers (along with the other public objects) are empty?
news:8764ar$ia66@adesknews2.autodesk.com...
> Public PI As Double
> Public KX As Single
> Public KY As Single
> KX = 1
> KZ = 1
> IsFile = False
> PI = 4 * Atn(1)
> end sub
> sub Mmodifica()
> end sub
> end button!).
I must run a Lisp routine from VBA for the old discussion of the tracking
mouse.
I don'have in vba the mousemove event , in lisp i use "grread" and get the
mouse coordinates tracked on the screen, then I use a lisp routine for draw
my function in real time tracked by mouse. When the user click on a point,
My lisp routine ends and pass the coordinate point to VBA.
I Assure you that now is all resolved!
The only problem is that when I return from VLisp I find all of my global
variables Resetted (Empty or =0) and also my object handling layers
resetted...
I'have however resolved Saving my variabled into a file and subsequently
refresh them with this file.
Bye Maverick!
