- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, i would like some help here,
i have rearranged the code below so as to spellnumber but the result doesnot in AutoCAD
The problem is, in excel it works normally as you can see in the image attached but in AutoCAD he gives me error Run-time error 5: Invalid procedure.
down first is the working image in microsoft excel
Now i leave the code, (He spells the numbers in portuguese) so an error is occuring as i have mentioned before
Public Function ConverterParaExtenso7(NumeroParaConverter As String) As String
Dim sExtensoFinal As String, sExtensoAtual As String
Dim i As Integer
Dim iQtdGrupos As Integer
Dim sDecimais As String
Dim sMoedaSing As String, sMoedaPlu As String, sCentavos As String
Dim bSufMoeda As Boolean
'Separa os Decimais
If InStr(1, NumeroParaConverter, ",") > 0 Then
sDecimais = Right(NumeroParaConverter, Len(NumeroParaConverter) - InStr(1, NumeroParaConverter, ","))
NumeroParaConverter = Mid(NumeroParaConverter, 1, InStr(1, NumeroParaConverter, ",") - 1)
End If
'Obtém a separação de milhares
iQtdGrupos = Fix(Len(NumeroParaConverter) / 3)
If Len(NumeroParaConverter) Mod 3 > 0 Then
iQtdGrupos = iQtdGrupos + 1
End If
'Chama as funções para escrever o número
If iQtdGrupos > 2 Then bSufMoeda = True
For i = iQtdGrupos To 1 Step -1
sExtensoAtual = DesmembraValor(NumeroParaConverter, i)
If i = 1 Then
If sExtensoAtual = "" Then
sExtensoFinal = sExtensoFinal & sExtensoAtual
Else
If sExtensoFinal = "" Then
Else
sExtensoFinal = sExtensoFinal & " " & sExtensoAtual
End If
End If
Else
End If
Select Case i
Case 1, 2
If sExtensoAtual <> "" Then
bSufMoeda = False
End If
End Select
End If
Next i
'Define a moeda
sMoedaPlu = ""
sMoedaSing = ""
If bSufMoeda = True Then sMoedaPlu = " de "
'Escreve os Centavos
sCentavos = EscreveCentavos(sDecimais)
'Adiciona a moeda e os centavos
sExtensoFinal = IIf((sExtensoFinal = ""), "", sExtensoFinal & IIf((sExtensoFinal = "um"), sMoedaSing, sMoedaPlu)) _
& IIf((sExtensoFinal = ""), sCentavos, IIf((sCentavos = ""), "", " virgula " & sCentavos))
'retorna o resultado
ConverterParaExtenso7 = sExtensoFinal
End Function
Private Function DesmembraValor(sValor As String, iGrupoDiv As Integer) As String
Dim iValor As Integer
Dim sExtenso As String
Dim iDivResto As Integer
Dim iDivInteiro As Integer
Dim iPosInicMid As Integer
Dim iTamMid As Integer
Dim sComplemento As String
Dim vArrDez1 As Variant
Dim vArrDez2 As Variant
Dim vArrCentena As Variant
vArrDez1 = Array("", "um", "dois", "três", "quatro", "cinco", "seis", "sete", "oito", "nove", _
"dez", "onze", "doze", "treze", "quatorze", "quinze", "dezesseis", "dezessete", _
"dezoito", "dezenove")
vArrDez2 = Array("vinte", "trinta", "quarenta", "cinquenta", "sessenta", _
"setenta", "oitenta", "noventa")
vArrCentena = Array("cem", "cento", "duzentos", "trezentos", "quatrocentos", _
"quinhentos", "seiscentos", "setecentos", "oitocentos", "novecentos")
'Pega o Valor a ser escrito e desmembra para o grupo numérico correto
iPosInicMid = Len(sValor) - ((3 * iGrupoDiv) - 1)
If iPosInicMid <= 1 Then
iTamMid = 2 + iPosInicMid
Else
iTamMid = 3
End If
If iPosInicMid < 1 Then iPosInicMid = 1
iValor = CInt(Mid(sValor, iPosInicMid, iTamMid))
Select Case iGrupoDiv
Case 2
sComplemento = " mil"
Case 3
If iValor = 1 Then
sComplemento = " milhão"
Else
sComplemento = " milhões"
End If
Case 4
If iValor = 1 Then
sComplemento = " bilhão"
Else
sComplemento = " bilhões"
End If
Case 5
If iValor = 1 Then
sComplemento = " trilhão"
Else
sComplemento = " trilhões"
End If
End Select
Select Case iValor
Case 0 To 19
sExtenso = vArrDez1(iValor)
Case 20 To 99
iDivInteiro = Fix(iValor / 10)
iDivResto = iValor Mod 10
If iDivResto = 0 Then
sExtenso = vArrDez2(iDivInteiro - 2)
Else
sExtenso = vArrDez2(iDivInteiro - 2) & " e " & vArrDez1(iDivResto)
End If
Case 100 To 999
iDivInteiro = Fix(iValor / 100)
iDivResto = iValor Mod 100
If iDivInteiro = 1 Then
sExtenso = vArrCentena(0) 'Cem
Else
sExtenso = vArrCentena(iDivInteiro) 'inteiro maior que 100
End If
Else
sExtenso = vArrCentena(iDivInteiro) & " e "
Select Case iDivResto
Case 0 To 19
sExtenso = sExtenso & vArrDez1(iDivResto)
Case 20 To 99
iDivInteiro2 = Fix(iDivResto / 10)
iDivResto2 = iDivResto Mod 10
If iDivResto2 = 0 Then
sExtenso = sExtenso & vArrDez2(iDivInteiro2 - 2)
Else
sExtenso = sExtenso & vArrDez2(iDivInteiro2 - 2) & " e " & vArrDez1(iDivResto2)
End If
End Select
End If
End Select
DesmembraValor = sExtenso & IIf(iValor > 0, sComplemento, "")
End Function
Private Function EscreveCentavos(sCent As String) As String
Dim iCent As Integer
'Adequando para duas casas decimais
iCent = Fix(sCent & String(2 - Len(sCent), "0"))
'Escrevendo Singular ou plural
If iCent = 1 Then
sComplemento = ""
Else
sComplemento = ""
End If
'Calculando os valores
Select Case iCent
Case 0 To 19
sExtenso = vArrDez1(iCent)
Case 20 To 99
iDivInteiro = Fix(iCent / 10)
iDivResto = iCent Mod 10
Else
End If
End Select
EscreveCentavos = IIf(iCent > 0, sExtenso & sComplemento, "")
End Function
Rosario Dilo
Regards
