Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Spell number
Spell number
ramd401
Message 1 of 15
Spell number
ramd401
Hi, i would like some help here,
i have rearranged the code below so as to spellnumber but the result doesnot in AutoCAD
The problem is, in excel it works normally as you can see in the image attached but in AutoCAD he gives me error Run-time error 5: Invalid procedure.
down first is the working image in microsoft excel
Now i leave the code, (He spells the numbers in portuguese) so an error is occuring as i have mentioned before
Public Function ConverterParaExtenso7(NumeroParaConverter As String) As String
Dim sExtensoFinal As String, sExtensoAtual As String
Dim i As Integer
Dim iQtdGrupos As Integer
Dim sDecimais As String
Dim sMoedaSing As String, sMoedaPlu As String, sCentavos As String
Dim bSufMoeda As Boolean
'Separa os Decimais
If InStr(1, NumeroParaConverter, ",") > 0 Then
sDecimais = Right(NumeroParaConverter, Len(NumeroParaConverter) - InStr(1, NumeroParaConverter, ","))
NumeroParaConverter = Mid(NumeroParaConverter, 1, InStr(1, NumeroParaConverter, ",") - 1)
End If
'Obtém a separação de milhares
iQtdGrupos = Fix(Len(NumeroParaConverter) / 3)
If Len(NumeroParaConverter) Mod 3 > 0 Then
iQtdGrupos = iQtdGrupos + 1
End If
'Chama as funções para escrever o número
If iQtdGrupos > 2 Then bSufMoeda = True
For i = iQtdGrupos To 1 Step -1
sExtensoAtual = DesmembraValor(NumeroParaConverter, i)
If i = 1 Then
If sExtensoAtual = "" Then
sExtensoFinal = sExtensoFinal & sExtensoAtual
Else
If sExtensoFinal = "" Then
Else
sExtensoFinal = sExtensoFinal & " " & sExtensoAtual
End If
End If
Else
End If
Select Case i
Case 1, 2
If sExtensoAtual <> "" Then
bSufMoeda = False
End If
End Select
End If
Next i
'Define a moeda
sMoedaPlu = ""
sMoedaSing = ""
If bSufMoeda = True Then sMoedaPlu = " de "
'Escreve os Centavos
sCentavos = EscreveCentavos(sDecimais)
'Adiciona a moeda e os centavos
sExtensoFinal = IIf((sExtensoFinal = ""), "", sExtensoFinal & IIf((sExtensoFinal = "um"), sMoedaSing, sMoedaPlu)) _
& IIf((sExtensoFinal = ""), sCentavos, IIf((sCentavos = ""), "", " virgula " & sCentavos))
'retorna o resultado
ConverterParaExtenso7 = sExtensoFinal
End Function
Private Function DesmembraValor(sValor As String, iGrupoDiv As Integer) As String
Dim iValor As Integer
Dim sExtenso As String
Dim iDivResto As Integer
Dim iDivInteiro As Integer
Dim iPosInicMid As Integer
Dim iTamMid As Integer
Dim sComplemento As String
Dim vArrDez1 As Variant
Dim vArrDez2 As Variant
Dim vArrCentena As Variant
vArrDez1 = Array("", "um", "dois", "três", "quatro", "cinco", "seis", "sete", "oito", "nove", _
"dez", "onze", "doze", "treze", "quatorze", "quinze", "dezesseis", "dezessete", _
"dezoito", "dezenove")
vArrDez2 = Array("vinte", "trinta", "quarenta", "cinquenta", "sessenta", _
"setenta", "oitenta", "noventa")
vArrCentena = Array("cem", "cento", "duzentos", "trezentos", "quatrocentos", _
"quinhentos", "seiscentos", "setecentos", "oitocentos", "novecentos")
'Pega o Valor a ser escrito e desmembra para o grupo numérico correto
iPosInicMid = Len(sValor) - ((3 * iGrupoDiv) - 1)
If iPosInicMid <= 1 Then
iTamMid = 2 + iPosInicMid
Else
iTamMid = 3
End If
If iPosInicMid < 1 Then iPosInicMid = 1
iValor = CInt(Mid(sValor, iPosInicMid, iTamMid))
Select Case iGrupoDiv
Case 2
sComplemento = " mil"
Case 3
If iValor = 1 Then
sComplemento = " milhão"
Else
sComplemento = " milhões"
End If
Case 4
If iValor = 1 Then
sComplemento = " bilhão"
Else
sComplemento = " bilhões"
End If
Case 5
If iValor = 1 Then
sComplemento = " trilhão"
Else
sComplemento = " trilhões"
End If
End Select
Select Case iValor
Case 0 To 19
sExtenso = vArrDez1(iValor)
Case 20 To 99
iDivInteiro = Fix(iValor / 10)
iDivResto = iValor Mod 10
If iDivResto = 0 Then
sExtenso = vArrDez2(iDivInteiro - 2)
Else
sExtenso = vArrDez2(iDivInteiro - 2) & " e " & vArrDez1(iDivResto)
End If
Case 100 To 999
iDivInteiro = Fix(iValor / 100)
iDivResto = iValor Mod 100
If iDivInteiro = 1 Then
sExtenso = vArrCentena(0) 'Cem
Else
sExtenso = vArrCentena(iDivInteiro) 'inteiro maior que 100
End If
Else
sExtenso = vArrCentena(iDivInteiro) & " e "
Select Case iDivResto
Case 0 To 19
sExtenso = sExtenso & vArrDez1(iDivResto)
Case 20 To 99
iDivInteiro2 = Fix(iDivResto / 10)
iDivResto2 = iDivResto Mod 10
If iDivResto2 = 0 Then
sExtenso = sExtenso & vArrDez2(iDivInteiro2 - 2)
Else
sExtenso = sExtenso & vArrDez2(iDivInteiro2 - 2) & " e " & vArrDez1(iDivResto2)
End If
End Select
End If
End Select
DesmembraValor = sExtenso & IIf(iValor > 0, sComplemento, "")
End Function
Private Function EscreveCentavos(sCent As String) As String
Dim iCent As Integer
'Adequando para duas casas decimais
iCent = Fix(sCent & String(2 - Len(sCent), "0"))
'Escrevendo Singular ou plural
If iCent = 1 Then
sComplemento = ""
Else
sComplemento = ""
End If
'Calculando os valores
Select Case iCent
Case 0 To 19
sExtenso = vArrDez1(iCent)
Case 20 To 99
iDivInteiro = Fix(iCent / 10)
iDivResto = iCent Mod 10
Else
End If
End Select
EscreveCentavos = IIf(iCent > 0, sExtenso & sComplemento, "")
End Function
Rosario Dilo
Regards
Replies (14)
Message 2 of 15
what line of your code is throwing that error? (click "Debug" button in the error dialog box to see that highlighted), and with which input string?
in the meanwhile you could check for what decimal separator convention is adopted in your AutoCAD VBA
Message 3 of 15
ramd401
Hi @Anonymous iam receaving errors in these two lines showed in the attached images
Rosario Dilo
Regards
Message 4 of 15
please answer all questions in proper detail
1) with reference to your last post first screenshot: what error is throwing and with what input string?
2) with reference to your last post second screenshot: what input string lead to the error?
3) have you made your mind up about decimal separator?
   you could place a break point at
 then, when hitting that break point query immediate window with
?NumeroParaConverter, CDbl(NumeroParaConverter)
and see if both returned values fit your expectations
Message 5 of 15
ramd401
Hi @Anonymous
1 ) with the reference of last post, first screnshot the error is (Run-time error `5` , Invalid procedure call or argument)
2 ) secong screnshot the string error is (sDecimais) if i omite this lines it works but can not give the the decimal spelling
3 ) can you indicate me in wich line i can put the break point and how? cause i had not made my mind up decimal separator
Message 6 of 15
what is the number you wanted to spell and passed as "NumeroParaConverter" argument to ConverterParaExtenso7() function?
Message 7 of 15
ramd401
Hi, @Anonymous i would like you to test the script and see exactly the errors and corect that, you can after teste this number 3.456,24  so the spelling in portuguese is: três mil quatrocentos e cinquenta e seis virgula vinte e quatro.
Rosario Dilo
Regards
Message 8 of 15
running the following sub:
Sub main()
    Debug.Print ConverterParaExtenso7("3.456,24")
End Sub
it returns
with no error
the same happens with:
Debug.Print ConverterParaExtenso7("3456,24")
while if I try:
Debug.Print ConverterParaExtenso7("3456.24")
it throws a "Run-time error '13': Type mismatch" error at code line
Message 9 of 15
ramd401
Hi @Anonymous so this is not the point (to convert only a number).
I really need the full script to convert any number he finds as it is happening in excel,
Look, the atached image represents my userform, when i click "Área e perimetro" he asks me to select a polyline and after he gives this result in the first textbox so the second textbox  has to spell the number from the first one, so, there is where i find this errors.
So what i need is to see the script be able to spell normally any number as it is happening in access, i only right anymumber in a cell and it spells that
Message 10 of 15
Well, your first post was about some error in the attached code
And I told you your code was running correctly as long as decimal points are properly input
Now you are talking about some "full script" and a Userform
So:
- is the original issue of this thread ("error Run-time error 5: Invalid procedure") solved?
If so, please mark my answer as the solution ans open a new thread to face any new issue (like any Userfom one) toghether with all the code needed
If not (your attached code is still throwing error in the way of spelling a number) post the very conditions under which it does so, showing the code that is calling ConverterParaExtenso7() as well (and some effort on your part, too ...)
Message 11 of 15
ramd401
Hi @Anonymous as i have told, the problem are the lines i have mentioned, if i clean them it spells but without the decimals, iam not so expert yet in vba, i have already done many modifications but did not work so, i woul like an ideia like, replace the line x by this and that, iam still continuing also see what to correct.
Rosário Dilo - regards
Message 12 of 15
I cannot but repeat myself
"If not (your attached code is still throwing error in the way of spelling a number) post the very conditions under which it does so, showing the code that is calling ConverterParaExtenso7() as well"
If you don't provide all what aboce I'm unable to help you further
Message 13 of 15
ramd401
Hi @Anonymous
the first textbox is textbox50 where i get the number to be converted
the second text box is textbox70 where i try to spell the number.
To send the text to be spelled in text box 70 iam using the following code in text box50:
Private Sub TextBox50_Change()
TextBox70.Text = ConverterParaExtenso(TextBox50.Text)
End Sub
Message 14 of 15
you make it hard to help you
I'm nearly begging you for a real and complete example that throws that error and you're giving details bit after bit
anyhow, taking the "daily bit" into account I cannot but remind you to make your mind up about the decimal separator issue
so:
- what's the actual TextBox50.Text string that's being passed to ConverterParaExtenso() sub?
  may be it has some dot (".") separator that isn't recognized as such by your ConverterParaExtenso() sub
  in this case you may want to treat that string before passing to your sub, like for instance:
TextBox70.Text = ConverterParaExtenso(Replace(TextBox50.Text,".",",") '<--| substitute the "dot" decimal separator with a "comma" one
- how many decimal is your ConverterParaExtenso() sub able to handle?
  may be it's able to handle up to two decimals
  in this case you may want to enhance the treatment of the string to pass to your sub, like for instance:
TextBox70.Text = ConverterParaExtenso(round(Replace(TextBox50.Text,".",",") ,2)) '<--| round to two decimals
I'm quite sure that if you play a little bit with what above, with some small "trial and error" activity you should come to the solution
Message 15 of 15
ramd401
Now i have got it like this and it works
Private Sub TextBox50_Exit(ByVal Cancel As MSForms.ReturnBoolean)
End Sub
thanks for all
