Message 1 of 1
IAcad plot failed vba
01:18 AM
Hello community i have the below code. This code works perfectly for one drawing of autocad, when it goes to the second one. It prints me an error. IAcadPlot failed. Why is that?
The below code is an iteration from a file that opens a drawing one at a time and converts it to PNG and stores it to a new location.
In order for you to setup you need:
A folder at c:/t/dwgFolder
A folder at c:/t/PNG_files_Storage
And a custom paper size.In my case it is named "my_paper_size"
Then you can start debugging. Add two drawings to the dwgFolder.
Public Sub MainForPngStep()
Dim DrawingList As Collection
'First we must see if drawings exist from meridian if there are no drawings we should quit Autocad'
Set DrawingList = GetDrawingsFilePath()
If DrawingList.Count = 0 Then
'No drawings were indide the folder so Autocad should close'
AcadApplication.Quit
'If the above statement is not true then we have drawings to convert'
'So we need to open them and print to png'
'Then we iterate over the collection for the program to '
For Each drawing In DrawingList
PrintToPng (drawing)
'The final step is to close the drawing'
ThisDrawing.Close (False)
Next
End Sub
Public Function GetDrawingsFilePath() As Collection
'This does work
Dim objFSO As Object
Dim objFolder As Object
Dim objFile As Object
Dim i As Integer
Dim drawingCollection As New Collection
'Create an instance of the FileSystemObject
Set objFSO = CreateObject("Scripting.FileSystemObject")
'Get the folder object
Set objFolder = objFSO.GetFolder("C:\t\dwgFolder")
'loops through each file in the directory and prints their names and path
Dim filePath As String
For Each objFile In objFolder.Files
'MsgBox (CStr(objFile.Path))
filePath = CStr(objFile.Path)
drawingCollection.Add filePath
Next objFile
Set GetDrawingsFilePath = drawingCollection
End Function
Public Function PrintToPng(filePath As String) As Boolean
'We call the open drawings here because '
Dim CanOpenDrawing As Boolean
CanOpenDrawing = OpenDrawings(filePath)
If CanOpenDrawing = False Then
'This means we could not open the drawing so we have to iterate to the next one'
'Failing here is the same of failing at converting for png'
PrintToPng = False
'This should be a constant since it is our test directory'
'This directory is where all the PNG files will be stored'
ZoomExtents
Dim sourceDir As String
sourceDir = "C:\t\PNG_files_Storage\"
'These three variables will help set the paper size'
Dim mediaNames As Variant
Dim name As String
Dim siz As String
'In this value the complete path will be stored'
Dim pngFile As String
'This value will be responsible for storing the full name of the active drawing'
Dim drawingName As String
Dim pngExtension As String
pngExtension = ".png"
'MsgBox (ThisDrawing.Name)
drawingName = ThisDrawing.name
'First we must remove the .dwg extension'
drawingName = TrimPath(drawingName)
'Then We build the final path'
pngFile = ConcatenateString(sourceDir, drawingName)
pngFile = ConcatenateString(pngFile, pngExtension)
MsgBox (pngFile)
Dim layout As AcadLayout
Set layout = ThisDrawing.ActiveLayout
'Do not really know Autocad has some pre configurations for printing reasonable'
layout.ConfigName = "PublishToWeb PNG.pc3"
layout.PaperUnits = acPixels
'Here we set the paper size'
siz = "my_paper_size"
mediaNames = layout.GetCanonicalMediaNames
For x = LBound(mediaNames) To UBound(mediaNames)
name = layout.GetLocaleMediaName(mediaNames(x))
If InStr(1, name, siz, vbTextCompare) = 1 Then
layout.CanonicalMediaName = mediaNames(x)
layout.RefreshPlotDeviceInfo
Next
Dim result As Boolean
result = ThisDrawing.Plot.PlotToFile(pngFile)
If result Then
PrintToPng = result
Else
PrintToPng = result
End Function
Function OpenDrawings(filePath As String) As Boolean
dwgName = filePath
If Dir(dwgName) <> "" Then
ThisDrawing.Application.Documents.Open dwgName
OpenDrawings = True
Else
OpenDrawings = False
End Function
'Helper Functions'
Public Function ConcatenateString(first As String, second As String) As String
ConcatenateString = first + second
End Function
Public Function TrimPath(pathToTrim As String) As String
Dim trimmedString As String
trimmedString = pathToTrim
trimmedString = RTrim(trimmedString)
Dim length As Long
length = Len(trimmedString)
trimmedString = Left(trimmedString, length - 4)
'MsgBox ("This is the trimmed path " & trimmedString)
TrimPath = trimmedString
End Function
