select all items in the selectionset
flowerpapa
Message 1 of 29
flowerpapa
I have initialized a AcadSelectionset, and have added few items in the selectionset.
Now i want to select all items present in the particular selectionset only
Replies (28)
Message 2 of 29
Ed__Jobe
By definition, if they're in the ss, they are selected. The ss does have a Highlight method, but it doesn't behave like regular acad, i.e. if you end the command they don't unhighlight. You have to do that by setting the Highlight property to False. Just use the ss as a grouping entity to iterate the objects you want to work on. For example, if you want to change their color, use For..Each to change the color property of each entity.
How did you put ents in the ss? Typically, you use one of the Select method, e.g. SelectOnScreen.
Ed
How to post your code.
Message 3 of 29
flowerpapa
Hello Ed.Joe,
Thanks for your reply
 I just created Ent as array of objects, then by using additems, objects added to ss selectionset,
Now I have Items(objects) in ss.list,
I struggling to select(not highlight) only those objects in the CAD window(modelspace).
Message 4 of 29
Ed__Jobe
What are you expecting to happen?  The purpose of "selecting" is to get entities into the SelectionSet.
Normally, you would let the user select the items by calling one of the SelectionSet.Select* methods. If you know what items are to be selected, you can add them to the SelectionSet by calling the AddItems method, which you did. Once they are in the ss, they are "selected". You can now use the ss to work with the items. e.g.
ss.AddItems entArray
Dim ent As AcadEntity
For Each ent in ss
   ent.Color = ByLayer
Next ent
Ed
Message 5 of 29
flowerpapa
Hello Ed.Joe,
I have placed my code below for your reference,
I want to either select that selectionset (oss2) in the model space after i have additems nor set oss2 selectionset as activeselectionset
can you please advise me on the same?
i = 1
j = 0
On Error Resume Next
Set oss2 = ThisDrawing.SelectionSets.Add("Temp2")
If Err.Number <> 0 Then
ThisDrawing.SelectionSets.Item("Temp2").Delete
End If
For Each oAcadobject In ThisDrawing.ModelSpace
If (TypeOf oAcadobject Is AeccPipeLabel) Then
Set oPipeLabel = oAcadobject
oTemp = oPipeLabel.LabelStyle.Name
oTemp1 = oPipeLabel.Handle
If InStr(LCase(oTemp), LCase("niet")) <> 0 Then
ReDim Preserve oPipeLabelNA(j)
Set oPipeLabelNA(j) = oPipeLabel
j = j + 1
End If
i = i + 1
'MsgBox oTemp
End If
Next
oss2.AddItems oPipeLabelNA
Debug.Print oss2.Count
Message 6 of 29
Norman_Yuan
If your purpose is to turn a programmatically selected entities in your AcadSelectionSet into a visually selected in AUtoCAD editor, as if they are selected by user manually, so that further command execution can be applied to them, then you can try following code (where I use code to select all circles, but in your case it is AeccPipeLabels):
Option Explicit
Public Sub SelectCircleVisually()
    Dim ss As AcadSelectionSet
    Set ss = GetCircleSelectionSet()
    If Not ss Is Nothing Then
        ThisDrawing.SendCommand "Select p " & vbCrLf
        ss.Delete     '' optional
    End If
End Sub
Private Function GetCircleSelectionSet() As AcadSelectionSet
    '' Create selection set
    Dim setName As String
    setName = "MySel"
    For Each ss In ThisDrawing.SelectionSets
        If ss.Name = setName Then
            ss.Delete
            Exit For
        End If
    Next
    Set ss = ThisDrawing.SelectionSets.Add(setName)
    '' Add all circles into the selection set
    Dim i As Integer
    Dim ents() As AcadEntity
    For Each ent In ThisDrawing.ModelSpace
        If TypeOf ent Is AcadCircle Then
            ReDim Preserve ents(i)
            Set ents(i) = ent
            i = i + 1
        End If
    Next
    If i > 0 Then
        ss.AddItems ents
    End If
    Set GetCircleSelectionSet = ss
End Function
Norman Yuan
Drive CAD With Code
Message 7 of 29
flowerpapa
Hi Norman.Yuvan,
It worked,
Big Thanks for your answer, Smiley Happy
Message 8 of 29
Norman_Yuan
It looked like I was only partially right in previous code: it only works for a newly opened drawing where user never selected anything. That is, the Previous SelectionSet in AutoCAD is only updated with VBA code when the code-created selectionset calls Select()/SelectOnScrceen() method; if the selectionset is fill with AddItems(), the Previous SelectionSet in AutoCAD does not get updated, thus the code I showed does not work.
Actually I discussed this in an old thread on the same topic, and suggested a way of solving this (see my reply posted on Oct. 16th, 2018 in that thread), but never actually got time to materialize it with code. Now that facing the same issue, I wrote some VBA code in the logic as I suggested there, and as I expected: it works. The key issue here for re-use "Previous" selection set in SendCommand, we need to build an AcadSelectionSet and call its Select()/SelectOnScreen() method, so that the "Previous" selection set (actually ThisDrawing.ActiveSelectionSet) would be updated. However, you cannot directly change ThisDrawing.ActiveSelectionSet (with Add/RemoveItems()).
See code and attached video clip below.
Option Explicit
Private Const XDATA_APP As String = "MySelApp"
Public Sub DoSelection()
    '' MsgBox "Prev Selected count: " & ThisDrawing.ActiveSelectionSet.Count
    Dim i As Integer
    '' Select all circles
    Dim ents As Variant
    ents = CollectTargetEntities()
    If UBound(ents) < 0 Then Exit Sub
    MsgBox "Targetted entity count: " & UBound(ents) + 1
    '' attach XData as selection filter
    SetSelectionXData ents, True
    SelectByXData
    '' detach Xdata as selection filter
    SetSelectionXData ents, False
    ThisDrawing.SendCommand "SELECT" & vbCr & "P" & vbCr & vbCr
End Sub
Private Function CollectTargetEntities() As Variant
    Dim i As Integer
            Set ents(i) = ent
            i = i + 1
        End If
    Next
    CollectTargetEntities = ents
End Function
Private Sub AttachSelectionXData(ent As AcadEntity)
    Dim dataType(0 To 1) As Integer
    Dim data(0 To 1) As Variant
    dataType(0) = 1001: dataType(1) = 1000
    data(0) = XDATA_APP: data(1) = "Xdata for selection"
    ent.SetXData dataType, data
End Sub
Private Sub DetachSelectionXData(ent As AcadEntity)
    Dim dataType(0) As Integer
    Dim data(0) As Variant
    dataType(0) = 1001
    data(0) = XDATA_APP
End Sub
Private Sub SelectByXData()
    Dim groupCode(0) As Integer
Dim dataCode(0) As Variant
groupCode(0) = 1001
dataCode(0) = XDATA_APP
ThisDrawing.ActiveSelectionSet.Select acSelectionSetAll, , , groupCode, dataCode
'' MsgBox "Selected: " & ss.Count End Sub Private Sub SetSelectionXData(ents As Variant, attach As Boolean) Dim i As Integer Dim ent As AcadEntity For i = 0 To UBound(ents) Set ent = ents(i) If attach Then AttachSelectionXData ent Else DetachSelectionXData ent End If Next End Sub
Norman Yuan
Drive CAD With Code
Message 9 of 29
Norman_Yuan
Option Explicit
    Dim i As Integer
    Dim ents As Variant
    SelectByXData
End Sub
    Dim i As Integer
            Set ents(i) = ent
            i = i + 1
        End If
    Next
End Function
End Sub
    dataType(0) = 1001
    data(0) = XDATA_APP
End Sub
    groupCode(0) = 1001
End Sub
    Dim i As Integer
        Set ent = ents(i)
        If attach Then
        Else
        End If
    Next
End Sub
Norman Yuan
Drive CAD With Code
Message 10 of 29
flowerpapa
Hello Norman.Yuvan,
Thanks for your effort, This what i needSmiley Happy
Message 11 of 29
george1985
Hi @Norman_Yuan ,
Thank you very much for the code!
I am trying to replicate it in C#.
What does XDATA_APP represent? It is an instance of which class?
When I try to use it as a string: "XDATA_APP", I get an error.
Thank you very much for the help.
Message 12 of 29
Ed__Jobe
@Norman_Yuan gave you a code "sample". You need to substitute the name of the xdata app that you want to work with.
Ed
Message 13 of 29
george1985
Thank you @Ed__Jobe
Can you give me an example of how to provide any xdata app?
If I try to manually assign XDATA in Autocad (by calling such command), the xdata app, is simply a string:
Message 14 of 29
Norman_Yuan
Since you mentioned that you use C#: are you doing AutoCAD .NET plugin? or automating AutoCAD via its COM API from external app/stand-alone EXE?
If you are doing AutoCAD .NET API plugin, there is no reason/no need to replicate what the VBA code does here.
Norman Yuan
Drive CAD With Code
Message 15 of 29
george1985
Hi @Norman_Yuan
Thank you for replying back. I am not using NET, but COM API and external WinForms.exe as you mentioned.
Can you tell me what is the type of the XDATA_APP object?
Message 16 of 29
Ed__Jobe
Yes, the data is a string, but you have to know which app wrote the string, otherwise other apps can mess with your xdata. See this help topic. In your screen captuere, "some_app" is the name of the app. The data you place in the next step is associated with the app.
Ed
Message 17 of 29
george1985
Thank you @Ed__Jobe ,
But I am not sure I understand.
Writing data is the next step, as you mentioned. But to assign the xdata, I have define the random name for my application? In a form of a string?
For example the VBA code from norman.yuan's code:
In C# would be:
dataCode[0] = "XDATA_APP";
If this is true, then I am getting an error message:
          (COMException): Invalid argument type in SetXData method
Interestingly, obtaining the xdata with "GetXData" method, works without issues. But the problem is that I manually assigned that xdata in Autocad with the use of _XDATA command. I would like to do that through COM API instead.
Message 18 of 29
Ed__Jobe
This is confusing. Norman gave you VBA code. If you are using C#, then post your code. Also, you should be posting in the NET forum. And there are other ways. Norman: "If you are doing AutoCAD .NET API plugin, there is no reason/no need to replicate what the VBA code does here."
Ed
Message 19 of 29
Norman_Yuan
If you read my VBA code carefully (at very top of my posted code), XDATA_APP is declared as "Const" string value, which is used as registered XData app name. It could be any string value, as long as it is not the same with any existing registered XData app name.
Since you indeed do an EXE app to automate AutoCAD, I am wondering what is the point to replicate the VBA code showed here? The OP wanted to run VBA code, so that the entities selected in AcadSelectionSet by VBA code would end up showing highlighted on AutoCAD editor, as if user manually selected these entities. That is, the VBA code only does the simulation of manual selection (I am sure you DO KNOW the different between entities being selected by code and selected by user clicking the entities). That is, after running the VBA code, user is left some entities being highlighted (with grips also shown). Then user are supposed to do something with these entities, such as run a command that accepts "select first" set of entities.
However, in your case, your user runs the EXE app with some action, then AutoCAD in the background has some entities selected/highlighted. Now, your user has to switch active app in windows' desktop to AutoCAD before the user can do anything. So, my point is, why use has to run 2 apps (the Exe and AutoCAD) and switch between them back and forth to do some CAD related work? I'd avoid doing this as much as possible.
Norman Yuan
Drive CAD With Code
Message 20 of 29
george1985
Thank you very much @Norman_Yuan
Regarding XDATA_APP variable:
 Is "MySelApp" previously defined in Autocad manually, before running your code?
The whole point of using WindowsForms application is, users will not have much interaction with Autocad actually.
One button on WindowsForms will import STEP file. Second button will select specific 3DSolids from that imported STEP file. And third button will drill them. So basically the user will only deal with WindowsForms. Autocad is there just in the background, and user is not going to manually run any commands in it.
