activate specific opened drawing
I need a little kick in the right direction, because I can't get it:
I have several dwg's open in AutoCAD and start a script which opens another file, does some stuff and closes the file.
After closing, I want to get back / reactivate the drawing where I started from and not activate the ltest opened file.
But how do I get it? (Especially I don't get how to set the active / start dwg as activeDwg)
The code
Dim ActiveDwg as AcadDocument
ActiveDwg = ThisDrawing '<---- the missing / wrong step, I think
' ...open another dwg
'..do some stuff
' ...close dwg
ThisDrawing.ActiveLayout = ThisDrawing(ActiveDwg)
It would be nice, if someone could give mi an advice 🙂
thanks and kind regards
BestFriendCZ
What about this ... save index your start document and use this
Sub Test()
    Dim activeDoc As AcadDocument
'    0 index of document which you want 0..1..2
    Set activeDoc = ThisDrawing.Application.Documents(0)
    activeDoc.Activate
End Sub
Ed__Jobe
A sample workflow for your subroutine:
Sub MyWorkProcess()
   Dim lastDwg As AcadDocument
   Set lastDwg = ThisDrawing
   ' Open new dwg and work on it
   lastDwg.Activate
End Sub
Ed
How to post your code.
Both ways work - thanks a lot! Man Happy
kind regards
Stumbled across this solution, it's a good one, but I'm thinking if you can let the user decide where the right drawing is (because it might change each day you use it), like this:
Sub cycleDwgs()
Dim i As Long, docTot As Long
docTot = ThisDrawing.Application.Documents.Count
For i = 1 To docTot
Set activeDoc = ThisDrawing.Application.Documents(i - 1)
Debug.Print activeDoc.Name
If MsgBox("Is this the document you're looking for?" & vbCrLf & vbCrLf & activeDoc.Name, vbYesNo + vbQuestion, "This dwg?") = vbYes Then
activeDoc.Activate
Exit For
Next i
'Continue using the correct document here, but call it as "activeDoc"
End Sub
