PL line vertex doesn't move in Z axis
maxwinkens
maxwinkens
Schermafbeelding 2019-03-13 om 14.45.32.pngSchermafbeelding 2019-03-13 om 14.45.53.png
I want to take the vertex in the front 10 cm higher. After selection of the vertex I bring it up and type in 10, then press enter and nothing will happen. what do I do wrong? (PL lines)
Ed__Jobe
Polylines are 2D entities. They can't have vertices in different planes. You have to rotate the whole polyline. Try the 3DROTATE command.
Ed
How to post your code.
maxwinkens
I doesn't want to rotate the whole line but just bring up the front vertex point
thanks for your reply anyway
Ed__Jobe
That's impossible. It goes against the definition of a polyline. Your only option is to break the polyline at the point you want it to "bend" and rotate the new, smaller portion.
Ed
Ed__Jobe
Another option would be to create a solid of the main body and another solid of the area to remove and then subtract the second one from the first one. To create the second polyline, you need to change the UCS to the XZ plane.
Ed
