Run a AutoCAD command using vba but don't show that in command line
mrhasanLCLPE
mrhasanLCLPE
Hello all,
I want to run a AutoCAD command using vba like,
    ThisDrawing.SendCommand ("RemoveSizeGroup ")
This is a custom command & there is lot's of custom command I used in my macro.
So, I don't want to display those command in command line.
How can I implement this ?
nucliabrasil
Tried this way ?
ThisDrawing.SendCommand  vbcr &  RemoveSizeGroup & vbcr
nucliabrasil
Sorry!
ThisDrawing.SendCommand  "RemoveSizeGroup" & vbCr
Ed__Jobe
As the name of the SendCommand method implies, an acutal command is sent to the command line. VBA does not execute the command. It runs from the command line after all your vba code finishes. Thus, there is no way to stop it. The only thing you can do is replicate what the command does via vba.
Ed
How to post your code.
mrhasanLCLPE
It's not working.
Alfred.NESWADBA
you can first try to disable CMDECHO, if that does not help you can change the setting of  NOMUTT to 1 (>>>details<<<), but take care to reset this value when your macro finished, otherwise the user would not see any input in the command-line any more.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
