Open new then save with name
Message 1 of 10
With the following code I can end up opening a new
excel file.  Now I would like to save that file.  How do I do
that?  I have looked in excel vba help with no help from it.  I'm
doing this from an ACAD vba module.
David M.
Gardner
Change the DOT to reply
Replies (9)
Message 2 of 10
fxcastil
David,
There are three methods for saving an excel file/workbook
Save, SaveAs,SaveCopyAs
ActiveWorkbook.Save
WorkBook.SaveAs Filename:=NewFileName
ActiveWorkbook.SaveCopyAs "C:\TEMP\XXXX.XLS"
In addition to close a workbook with out saving use
Workbooks("BOOK1.XLS").Close SaveChanges:=False
To find methods these use the object browser in Excel IDE (VBA) environment
Fred Castillo
Message 3 of 10
The following is a excerpt from Excel 2003 VBA Help
for Workbook.SaveAs
Saves changes to the workbook in a different file.
expression.SaveAs(
class=bterm>FileName
, FileFormat,
class=bterm>Password
, WriteResPassword,
class=bterm>ReadOnlyRecommended
class=bterm>CreateBackup
, AccessMode,
class=bterm>ConflictResolution
, AddToMru,
TextCodepage,
class=bterm>TextVisualLayout
class=bterm>Local
expression    Required. An expression that
returns one of the above objects.
Filename
Optional Variant. A string that indicates the name of the
file to be saved. You can include a full path; if you don't, Microsoft Excel
saves the file in the current folder.
FileFormat
Optional Variant. The file format to use when you save the
file. For a list of valid choices, see the
href="mk:@MSITStore:C:\Program%20Files\Microsoft%20Office\OFFICE11\1033\vbaxl10.chm::/html/xlproFil...
property. For an existing file, the default format is the last file format
specified; for a new file, the default is the format of the version of Excel
being used.
Password
Optional Variant. A case-sensitive string (no more than 15
characters) that indicates the protection password to be given to the
file.
WriteResPassword
write-reservation password for this file. If a file is saved with the password
and the password isn't supplied when the file is opened, the file is opened as
read-only.
class=runinhead>ReadOnlyRecommended
    Optional
class=bterm>Variant
. True to display a message when the
file is opened, recommending that the file be opened as read-only.
CreateBackup
Optional Variant. True to create a backup
file.
class=runinhead>AccessMode
   Optional
class=DropDown onkeypress=Outline2() onclick=Outline2()
href="mk:@MSITStore:C:\Program%20Files\Mic...
size=1>.
class=runinhead>ConflictResolution
    Optional
href="mk:@MSITStore:C:\Program%20Files\Microsoft%20Office\OFFICE11\1033\vbaxl10.chm::/html/xlmthSav...
size=1>.
AddToMru
Optional Variant. True to add this
workbook to the list of recently used files. The default value is
class=bterm>False
TextCodePage
Optional Variant. Not used in U.S. English Microsoft
Excel.
TextVisualLayout
Excel.
Local   Optional
class=bterm>Variant
. True saves files against the
language of Microsoft Excel (including control panel settings).
class=bterm>False
(default) saves files against the language of
class=glossary onkeypress="AppendPopup(this,'ofVBA')"
onclick="AppendPopup(this,'ofVBA')"
href="m...
(which is
typically US English unless the VBA project where Workbooks.Open is run from is
an old internationalized XL5/95 VBA project).
Hopefully this helps.
Phil Custer II, P.E.
Custer Services,
Inc.
href="mailto:custer@landfillgas.com">custer@landfillgas.com
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
new excel file.  Now I would like to save that file.  How do I do
David M.
Gardner
Message 4 of 10
I'm using this code:
Dim excelApp As Object
Dim wbkObj As Object
Dim shtObj As Object
On Error Resume Next
Set excelApp = GetObject(, "Excel.Application")
If Err <> 0 Then
Err.Clear
Set excelApp = CreateObject("Excel.Application")
If Err <> 0 Then
MsgBox "Could not start Excel", vbExclamation
End
End If
End If
excelApp.Visible = True
Set wbkObj = Workbooks.Open(FileName:=strDWGIndex)
If Workbooks.COUNT = "0" Then
Workbooks.Add ("X:\drawing index.xls")
Workbooks.SaveAs FileName:=strDWGIndex
End If
Set wbkObj = Nothing
Set excelApp = Nothing
and I get this error highlighting the ".saveas"
David M. Gardner
wrote in message news:5088689@discussion.autodesk.com...
David,
ActiveWorkbook.Save
Fred Castillo
Message 5 of 10
Here is the problem:
Workbooks.Count is a number value, not a text string value. That is why
the...Add() and ...SaveAs() are never executed. It should be:
If Workbooks.Count=0 Then...
The other problen is to use "On Error Resume Next" without trying to handle
possible error.
In you case, the statement
If Workbooks.Count="0"
generates a error fo "Type misnatch", but the process simply RESUMEs to next
line and continue, so you do not notice something wrong has happened.
My thumb of rule is to not use "On Error Resume Next" unless you try to
examine Err object is each following line of code that could reuilt in
runtime exception.
"David M. Gardner" wrote in message
news:5088791@discussion.autodesk.com...
If Err <> 0 Then
Err.Clear
If Err <> 0 Then
End
End If
End If
I
End If
David M. Gardner
David,
ActiveWorkbook.Save
Fred Castillo
Message 6 of 10
Thank you for that bit of info. But that does not answer/fix the error I
get. If you can look at my 2nd post that has the error attached.
David M. Gardner
"Norman Yuan" wrote in message
news:5089506@discussion.autodesk.com...
possible error.
runtime exception.
If Err <> 0 Then
Err.Clear
If Err <> 0 Then
End
End If
End If
I
End If
David M. Gardner
David,
ActiveWorkbook.Save
Fred Castillo
Message 7 of 10
Ah, you may want to try to qualify the Workbooks with excelApp. That is,
Replace:
Workbooks....
with:
excelApp.Workbooks...
news:5091764@discussion.autodesk.com...
David M. Gardner
possible error.
runtime exception.
If Err <> 0 Then
Err.Clear
If Err <> 0 Then
End
End If
End If
I
End If
David M. Gardner
David,
ActiveWorkbook.Save
Fred Castillo
Message 8 of 10
OK. I don't get the error anymore but it does not save the file.
David M. Gardner
news:5091822@discussion.autodesk.com...
Replace:
Workbooks....
with:
David M. Gardner
possible error.
runtime exception.
If Err <> 0 Then
Err.Clear
If Err <> 0 Then
End
End If
End If
I
End If
David M. Gardner
David,
ActiveWorkbook.Save
Fred Castillo
Message 9 of 10
Here is revised code:
If Err.Number <> 0 Then
Err.Clear
''End
Exit Sub 'or Function. NEVER use "End"
End If
End If
'' if the file strDWGIndex refers to does not exist, you will get error
on next line
Set wbkObj = excelApp.Workbooks.Open(FileName:=strDWGIndex)
''So handle the error if file not found
If Err.Number<>0 Then
If excelApp.Workbooks.COUNT = 0 Then
Set wbkObj=Workbooks.Add ("X:\drawing index.xls") ' 'You must
guarrantee "X:\drawing Index.xls" always exists
''Workbooks.SaveAs FileName:=strDWGIndex ''Workbooks does not
have a method called SaveAs(), Workbook does
wbkObj.SaveAs FileName:=strDWGIndex
End If
End If
'if you want Excel and the workbook to stay open. that is fine.
Otherwise, you should close it
'wbkObj.Close False ''Save/not save while closing
'excelApp.Quit ''Quit Excel application
news:5091937@discussion.autodesk.com...
David M. Gardner
Replace:
Workbooks....
with:
David M. Gardner
possible error.
runtime exception.
If Err <> 0 Then
Err.Clear
If Err <> 0 Then
End
End If
End If
I
End If
David M. Gardner
David,
ActiveWorkbook.Save
Fred Castillo
Message 10 of 10
Thank you.
David M. Gardner
news:5092347@discussion.autodesk.com...
Err.Clear
''End
End If
End If
on next line
End If
End If
David M. Gardner
Replace:
Workbooks....
with:
David M. Gardner
possible error.
runtime exception.
If Err <> 0 Then
Err.Clear
If Err <> 0 Then
End
End If
End If
I
End If
David M. Gardner
David,
ActiveWorkbook.Save
Fred Castillo
