VBA leaves an Excel process
Can anyone tell me why I run this code and it
leaves an Excel process running till I close ACAD?  And how can I stop this
from happening?
<snip>
Dim excelApp As Object
Dim wbkObj As
Object
Dim shtObj As Object
    On Error Resume
Next
    Set excelApp = GetObject(,
"Excel.Application")
    If Err <> 0
Then
Err.Clear
        Set excelApp =
CreateObject("Excel.Application")
If Err <> 0
Then
MsgBox "Could not start Excel",
vbExclamation
End
    excelApp.Visible = True
    Set
wbkObj = Workbooks.Open(FileName:=strDWGIndex)
    If
Workbooks.COUNT = "0" Then
Workbooks.Add
    Set wbkObj =
Nothing
    Set excelApp = Nothing
End Sub
<snip>
David M.
Gardner
Change the DOT to reply
Access the workbook object of the Excel application and make sure to close &
quit.....
Dim excelApp As Excel.Application
Dim wbkObj As Workbook
On Error Resume Next
Set excelApp = GetObject(, "Excel.Application")
If Err <> 0 Then
Err.Clear
Set excelApp = CreateObject("Excel.Application")
If Err <> 0 Then
MsgBox "Could not start Excel", vbExclamation
End
Set wbkObj = excelApp.Workbooks.Open("c:\test.xls")
If excelApp.Workbooks.Count = "0" Then
excelApp.Workbooks.Add
wbkObj.Close
excelApp.Quit
Set wbkObj = Nothing
"David M. Gardner" wrote in message
news:5088296@discussion.autodesk.com...
Can anyone tell me why I run this code and it leaves an Excel process
running till I close ACAD? And how can I stop this from happening?
You must quit excel when you are done.
[code]
Dim ExApp as Excel.Application
Dim NewExcelSession As Boolean
On Error Resume Next  ' if we fail on errors
then skip to error handler next
  Set ExApp = GetObject(,
"excel.application") ' Get Ref to Excel
  If Err <> 0 Then ' Can't
create object because Excel was not already open
Err.Clear
      Set ExApp =
CreateObject("excel.application")  ' Start
Excel
      If Err <> 0 Then ' Excel is not
installed fault
        Err.Raise
Err.Number  ' Raise error to calling
function
Else
        NewExcelSession =
True
Else
    NewExcelSession = False
  End
If
objExcelApp.Visible = True ' show excel so that errors can be shut
down
...    Do some work with
ExApp
Rem Insert code to close all open workbooks
first
If NewExcelSession Then   ' If a new
session then we can close it
  If ExApp.Workbooks.Count = 0
Then   ' check to see if there are no open Workbooks
first
    ExApp.Application.DisplayAlerts = False
' Turn off alerts
    ExApp.Application.Quit  ' End excel
session
Endif
Set ExApp = Nothing
[/code]
Phil Custer II, P.E.
Custer Services,
Inc.
href="mailto:custer@landfillgas.com">custer@landfillgas.com
<snip>
Dim wbkObj As
Object
    On Error Resume
Next
    If Err <> 0
Then
Err.Clear
        Set excelApp =
If Err <> 0
Then
vbExclamation
End
    Set
    If
Workbooks.Add
    Set wbkObj =
Nothing
End Sub
<snip>
David M.
Gardner
