Determine if an object's layer is frozen or thawed
I'm trying to calculate the total area of all polygons in the drawing whose layers include the prefix "AREA-" AND whose layer is not currently frozen. I don't want to include layers that are frozen.
I have gotten the calculation part down, as well as the layer prefix. How do I determine if the object's layer is frozen or thawed?
Here's what I've got so far...
Public Sub getareathawed()
Dim obj As AcadObject
totalArea = 0
For Each obj In ThisDrawing.ModelSpace
If obj.ObjectName = "AcDbPolyline" And InStr(1, obj.Layer, "AREA-", vbTextCompare) <> 0 Then
totalArea = totalArea + Format((obj.Area / 144), 0)
Next
MsgBox totalArea & " Sq. Ft. on AREA layers"
End Sub
fxcastil
from the object browser help files
Sub Example_Freeze()
' This example creates a new layer called "Freeze".
' It then displays the status of the Freeze property
' for the new layer, toggles the status of the
' Freeze property, and again displays it's status.
' After running this example, you can check the layer
' control on the Object Properties tool bar. It will
' show the new layer and the latest Freeze status.
Dim layerObj As AcadLayer
' Create the new layer
Set layerObj = ThisDrawing.Layers.Add("Freeze")
' Display the Freeze status of the new layer
GoSub DISPLAYSTATUS
' Toggle the status of the Freeze property for the layer
layerObj.Freeze = Not (layerObj.Freeze)
GoSub DISPLAYSTATUS
Exit Sub
DISPLAYSTATUS:
If layerObj.Freeze Then
MsgBox "Layer " & layerObj.name & " is frozen.", , "Freeze Example"
Else
MsgBox "Layer " & layerObj.name & " is thawed.", , "Freeze Example"
Return
End Sub
Sub Example_Lock()
' This example creates a new layer called "Lock".
' It then displays the status of the Lock property
' Lock property, and again displays it's status.
' show the new layer and the latest Lock status.
Set layerObj = ThisDrawing.Layers.Add("Lock")
' Display the Lock status of the new layer
GoSub DISPLAYSTATUS
' Toggle the status of the Lock property for the layer
layerObj.Lock = Not (layerObj.Lock)
GoSub DISPLAYSTATUS
Exit Sub
DISPLAYSTATUS:
If layerObj.Lock Then
MsgBox "Layer " & layerObj.name & " is locked.", , "Lock Example"
Else
MsgBox "Layer " & layerObj.name & " is unlocked.", , "Lock Example"
Return
End Sub
Fred Castillo
Ok, I copied that example code and used it, and it worked fine as is. However, ince I tried to apply the same stuff to my own code, it didn't work anymore. I'm partly confused because in the example, both the layer name and the property are called Freeze, so I'm not sure when it's referring to the layer by name or to the property.
I tried this before, but it didn't work:
totalArea = 0
If obj.ObjectName = "AcDbPolyline" And InStr(1, obj.Layer, "AREA-", vbTextCompare) 0 And obj.Layer.Freeze = False Then
Next
End Sub
I'm thinking that my syntax is wrong when evaluating the layer's Freeze property. Any tips on how to correct that?
You must test the Layer itself for the freeze property.....
If (obj.ObjectName = "AcDbPolyline") And (InStr(1, obj.Layer,
"AREA-", vbTextCompare) <> 0) _
And (ThisDrawing.Layers.Item(obj.Layer).Freeze = False) Then
wrote in message news:5088847@discussion.autodesk.com...
anymore.
Perfect! Thanks alot. That makes sense, and it works exactly how I want it to.
