How to show dimensions of objects
m09366023695
m09366023695
I have multi shapes.
I want to show all dimensions of each sides(the green lines).
BEYJd
I want to use `vba`.
I can show dimension a full square or rectangle shape.
for example to show a horizontal dimension I use this function:
Function createDimensionHorizental(x1, y1, x2, y2)
' This example creates an aligned dimension in model space and
' uses the TextHeight property to increase the height of the
' dimension text
Dim dimObj As AcadDimAligned
Dim point1(0 To 2) As Double, point2(0 To 2) As Double
Dim location(0 To 2) As Double
' Define the dimension
point1(0) = x1: point1(1) = y1: point1(2) = 0
point2(0) = x2: point2(1) = y1: point2(2) = 0
location(0) = x1: location(1) = y1 + 10: location(2) = 0
' Create an aligned dimension object in model space
Set dimObj = ThisDrawing.ModelSpace.AddDimAligned(point1, point2, location)
' Read and display current dimension text height
'MsgBox "The dimension text height for this object is currently set to: " & dimObj.TextHeight
' Increase the distance of the dimension gap
'Format the dimension object according to your needs.
With dimObj
.TextHeight = 30
.TextGap = 10 'The distance of the dimension text from the dimension line.
.Arrowhead1Type = 5 'acArrowOblique in early binding
.Arrowhead2Type = 5 'For the standard dimension arrow put 0 here.
.ArrowheadSize = 20
.ExtensionLineExtend = 10 'The amount to extend the extension line beyond the dimension line.
End With
ThisDrawing.Regen acAllViewports
End Function
Ray-Sync
Hi. me=userform1 ..... me.hide and me.show. This is my answer.
Private Sub CommandButton1_Click()
Dim Ent As AcadEntity
Dim pol(20) As AcadLWPolyline
Dim l(21) As AcadLine
Dim m As Variant, pt As Variant
Dim p(0 To 2) As Double
Dim r(21) As AcadDimAligned
Me.Hide
Call ThisDrawing.Utility.GetEntity(Ent, pt, "select line")
Set pol(0) = Ent
Set pol(1) = pol(0).Copy
m = pol(1).Explode
For i = 0 To 20
On Error Resume Next
Set l(i) = m(i)
p(0) = l(i).EndPoint(0): p(1) = l(i).EndPoint(1) + 1
Set r(i) = ThisDrawing.ModelSpace.AddDimAligned(l(i).StartPoint, l(i).EndPoint, p)
With r(i)
.HorizontalTextPosition = acHorzCentered
.VerticalTextPosition = acAbove
.TextHeight = 500
.PrimaryUnitsPrecision = acDimPrecisionTwo
End With
Next i
pol(1).Delete
For i = 0 To 20
l(i).Delete
Next i
ThisDrawing.Regen True
Me.show
End Sub
jefferson
Ed__Jobe
Have you tried the QDIM command?
You can write a program, but you need to define the rules for the program to follow. Maybe the rules that the QDIM command uses are good enough? You haven’t said much about which sides to include or exclude.
Ed
How to post your code.
