How to show dimensions of objects
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have multi shapes.
I want to show all dimensions of each sides(the green lines).
I want to use `vba`.
I can show dimension a full square or rectangle shape.
for example to show a horizontal dimension I use this function:
Function createDimensionHorizental(x1, y1, x2, y2)
' This example creates an aligned dimension in model space and
' uses the TextHeight property to increase the height of the
' dimension text
Dim dimObj As AcadDimAligned
Dim point1(0 To 2) As Double, point2(0 To 2) As Double
Dim location(0 To 2) As Double
' Define the dimension
point1(0) = x1: point1(1) = y1: point1(2) = 0
point2(0) = x2: point2(1) = y1: point2(2) = 0
location(0) = x1: location(1) = y1 + 10: location(2) = 0
' Create an aligned dimension object in model space
Set dimObj = ThisDrawing.ModelSpace.AddDimAligned(point1, point2, location)
' Read and display current dimension text height
'MsgBox "The dimension text height for this object is currently set to: " & dimObj.TextHeight
' Increase the distance of the dimension gap
'Format the dimension object according to your needs.
With dimObj
.TextHeight = 30
.TextGap = 10 'The distance of the dimension text from the dimension line.
.Arrowhead1Type = 5 'acArrowOblique in early binding
.Arrowhead2Type = 5 'For the standard dimension arrow put 0 here.
.ArrowheadSize = 20
.ExtensionLineExtend = 10 'The amount to extend the extension line beyond the dimension line.
End With
ThisDrawing.Regen acAllViewports
End Function
