How create line with block
m09366023695
m09366023695
hi
I want to create a line with blocks :
Function CreateLine(firstPoint, secondPoint)
    Dim StartPoint(0 To 2), insPt(0 To 2) As Double
    Dim MyBlock As AcadBlock
    Dim blockName As String
    Dim EndPoint(0 To 2) As Double
   blockName = "masoud"
    StartPoint(0) = firstPoint(0)
    StartPoint(1) = firstPoint(1)
    'StartPoint(2) = 0
    EndPoint(0) = secondPoint(0)
    EndPoint(1) = secondPoint(1)
    'EndPoint(2) = 0
    'With ThisDrawing.ModelSpace
    '.AddLine StartPoint, EndPoint
    '.Item(.Count - 1).Update
    'End With
    'Create a new block
     Set MyBlock = ThisDrawing.Blocks.Add(insPt, blockName)
    'ADD LINES DIRECT ON YOUR BLOCK
    MyBlock.AddLine StartPoint, EndPoint
    'Add the blockreference in model space
    ThisDrawing.ModelSpace.InsertBlock insPt, blockName, 1, 1, 1, 0
End Function
but I got this error:
invalid procedure call or argument.
I want to create line with block as I find it with specific name. because user want to delete it.
seabrahenrique
The error occurs because the declaration of the "Startpoint" variable in your first line. You did not put a type the variable:
Instead this, try to use this:
Dim StartPoint(0 To 2) As Double, insPt(0 To 2) As Double
I hope can help u.
Ed__Jobe
@m09366023695 wrote:
hi
If you get an error, tell us what line causes the error.
If you want to prevent users from deleting entities, put them on a locked layer.
objLine.Layer = "lockedLayer"
You can also use the LAYLCK command to change the Locked property of the layer that the line is on. Or:
ThisDrawing.Layers(objLine.Layer).Lock = True
Ed
How to post your code.
