How to create a menu item with vba
m09366023695
m09366023695
hi
I found this function to create menu:
Public Sub AddMenus()
'Jonathan D. Kriek
Dim currMenuGroup As AcadMenuGroup
Dim newMenu As AcadPopupMenu
Dim newMenuItem As AcadPopupMenuItem
Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item(0)
On Error Resume Next
'Assign new menu
Set newMenu = currMenuGroup.Menus.Item("TrinityTools")
'If menu doesn't exist then add it
If newMenu Is Nothing Then
Set newMenu = currMenuGroup.Menus.Add("TrinityTools")
'Check if Menu is displayed on MenuBar
If Not newMenu.OnMenuBar Then
'Add the eBLoader macro to the menu
Set newMenuItem = newMenu.AddMenuItem(newMenu.count + 1, _
"Release To eB", "-vbarun eBLoader ")
newMenuItem.HelpString = "Release To eB"
'Add the DrawingTypeLoad macro to the menu
"Set Drawing Type", "-vbarun DrawingTypeLoad ")
newMenuItem.HelpString = "Set Drawing Type"
'Display the menu on the menu bar
newMenu.InsertInMenuBar (ThisDrawing.Application.MenuBar.count + 1)
'Save menu
currMenuGroup.Save (acMenuFileCompiled)
End Sub
but after run it I cannot see a new menu.
seabrahenrique
Have you consider to use the "CUI" command to build your menu?
I guess is a better solution than build by a code.
I hope can help u.
m09366023695
I writing a macro and need to a menu to show user.
Ed__Jobe
Menus are not used very much anymore. By default, it is off and only the ribbon shows. Do you have MENUBAR set to 1?
Ed
How to post your code.
