Mine is very similar to that. I started with something similar, but added other features supported by the win32 api, like multiselect and longer paths. Save the code below to a class module.
Option Explicit
'Notice: Don't forget to set the OwnerHwnd property to the
'handle of the calling window in order to bind the dialog
'to the calling window.
'//The Win32 API Functions///
Private Declare Function GetSaveFileName Lib _
"COMDLG32.DLL" Alias "GetSaveFileNameA" _
(pOpenfilename As OPENFILENAME) As Long
Private Declare Function GetOpenFileName Lib _
"COMDLG32.DLL" Alias "GetOpenFileNameA" _
'//Available Flags///
Private Const OFN_ALLOWMULTISELECT = &H200
Private Const OFN_CREATEPROMPT = &H2000
Private Const OFN_ENABLEHOOK = &H20
Private Const OFN_ENABLETEMPLATE = &H40
Private Const OFN_ENABLETEMPLATEHANDLE = &H80
Private Const OFN_EXPLORER = &H80000 ' new look commdlg
Private Const OFN_EXTENSIONDIFFERENT = &H400
Private Const OFN_FILEMUSTEXIST = &H1000
Private Const OFN_HIDEREADONLY = &H4
Private Const OFN_LONGNAMES = &H200000 ' force long names for 3.x modules
Private Const OFN_NOCHANGEDIR = &H8
Private Const OFN_NODEREFERENCELINKS = &H100000
Private Const OFN_NOLONGNAMES = &H40000 ' force no long names for 4.x modules
Private Const OFN_NONETWORKBUTTON = &H20000
Private Const OFN_NOREADONLYRETURN = &H8000
Private Const OFN_NOTESTFILECREATE = &H10000
Private Const OFN_NOVALIDATE = &H100
Private Const OFN_OVERWRITEPROMPT = &H2
Private Const OFN_PATHMUSTEXIST = &H800
Private Const OFN_READONLY = &H1
Private Const OFN_SHAREAWARE = &H4000
Private Const OFN_SHAREFALLTHROUGH = 2
Private Const OFN_SHARENOWARN = 1
Private Const OFN_SHAREWARN = 0
Private Const OFN_SHOWHELP = &H10
'//The Structure
Private Type OPENFILENAME
lStructSize As Long
hwndOwner As Long
hInstance As Long
lpstrFilter As String
lpstrCustomFilter As String
nMaxCustFilter As Long
nFilterIndex As Long
lpstrFile As String
nMaxFile As Long
lpstrFileTitle As String
nMaxFileTitle As Long
lpstrInitialDir As String
lpstrTitle As String
Flags As Long
nFileOffset As Integer
nFileExtension As Integer
lpstrDefExt As String
lCustData As Long
lpfnHook As Long
lpTemplateName As String
End Type
'private class variables
Private lngHwnd As Long
Private strFilter As String
Private strTitle As String
Private strDir As String
Private strFile As String 'elj
Private lngSelectedFilter As Long
Private blnHideReadOnly As Boolean
Private blnMode As Boolean
Private Sub Class_Initialize()
'Set default values when
'class is first created
strDir = CurDir
strTitle = "Select File"
strFile = ""
strFilter = "All Files" _
& Chr$(0) & "*.*" & Chr$(0)
lngSelectedFilter = 0
lngHwnd = &O0 'Desktop
End Sub
Public Property Let OwnerHwnd(WindowHandle As Long)
'//FOR YOU TODO//
'Use the API to validate this handle
lngHwnd = WindowHandle
'R14 users who just want to use this code:
'Simple, don't set this property! the default
'of &0 will work fine for most of your needs
End Property
Public Property Get OwnerHwnd() As Long
OwnerHwnd = lngHwnd
End Property
'elj added property
Public Property Let MultiSelect(mode As Boolean)
blnMode = mode
End Property
'elj added property
Public Property Get MultiSelect() As Boolean
MultiSelect = blnMode
End Property
Public Property Get SelectedFilter() As Long
SelectedFilter = lngSelectedFilter
End Property
Public Property Let SelectedFilter(FilterNumber As Long)
lngSelectedFilter = FilterNumber
End Property
'elj added property
Public Property Let StartFile(FileName As String)
'don't allow null strings
If Not FileName = vbNullString Then
strFile = FileName
End If
End Property
'elj added property
Public Property Get StartFile() As String
StartFile = strFile
End Property
Public Property Let StartInDir(StartDir As String)
If Not StartDir = vbNullString Then
strDir = StartDir
End If
End Property
Public Property Get StartInDir() As String
StartInDir = strDir
End Property
Public Property Let Title(Caption As String)
If Not Caption = vbNullString Then
strTitle = Caption
End If
End Property
Public Property Get Title() As String
Title = strTitle
End Property
Public Property Let Filter(ByVal FilterString As String)
'Filters change the type of files that are
'displayed in the dialog. I have designed this
'validation to use the same filter format the
'Common dialog OCX uses:
'"All Files (*.*)|*.*"
Dim intPos As Integer
Do While InStr(FilterString, "|") > 0
intPos = InStr(FilterString, "|")
If intPos > 0 Then
FilterString = Left$(FilterString, intPos - 1) _
& Chr$(0) & Right$(FilterString, _
Len(FilterString) - intPos)
End If
Loop
If Right$(FilterString, 2) <> Chr$(0) & Chr$(0) Then
FilterString = FilterString & Chr$(0)
End If
strFilter = FilterString
End Property
Public Property Get Filter() As String
'Here we reverse the process and return
'the Filter in the same format that it was
'entered
Dim strTemp As String
strTemp = strFilter
Do While InStr(strTemp, Chr$(0)) > 0
intPos = InStr(strTemp, Chr$(0))
If intPos > 0 Then
strTemp = Left$(strTemp, intPos - 1) _
& "|" & Right$(strTemp, _
Len(strTemp) - intPos)
End If
Loop
If Right$(strTemp, 1) = "|" Then
strTemp = Left$(strTemp, Len(strTemp) - 1)
End If
Filter = strTemp
End Property
Public Property Let HideReadOnly(blnVal As Boolean)
'Simple one
blnHideReadOnly = blnVal
End Property
Public Property Get HideReadOnly() As Boolean
HideReadOnly = blnHideReadOnly
End Property
' Display and use the File open dialog
Public Function ShowOpen() As String
Dim udtStruct As OPENFILENAME
udtStruct.lStructSize = Len(udtStruct)
'Use our private variable
udtStruct.hwndOwner = lngHwnd
udtStruct.lpstrFilter = strFilter
udtStruct.nFilterIndex = lngSelectedFilter
'elj start
' udtStruct.lpstrFile = Space$(254) elj comment out
If Not strFile = vbNullString Then
udtStruct.lpstrFile = strFile & Space(254 - Len(strFile))
Else
End If
'elj end
udtStruct.nMaxFile = 255
udtStruct.lpstrFileTitle = Space$(254)
udtStruct.nMaxFileTitle = 255
udtStruct.lpstrInitialDir = strDir
udtStruct.lpstrTitle = strTitle
'Ok, here we test our boolean to
'set the flags
udtStruct.Flags = 0
If blnHideReadOnly Then udtStruct.Flags = OFN_HIDEREADONLY + udtStruct.Flags
If blnMode Then udtStruct.Flags = OFN_EXPLORER + OFN_ALLOWMULTISELECT + udtStruct.Flags
If GetOpenFileName(udtStruct) Then
strTemp = (Trim(udtStruct.lpstrFile))
ShowOpen = Mid(strTemp, 1, Len(strTemp) - 1)
End If
End Function
' Display and use the File Save dialog
Public Function ShowSave() As String
' udtStruct.lpstrFile = Space$(254) 'elj comment out
'elj start
Else
End If
'elj end
'Ok, here we test our flag
Else
udtStruct.Flags = 0
End If
If GetSaveFileName(udtStruct) Then
ShowSave = Mid(strTemp, 1, Len(strTemp) - 1)
End If
End Function
Ed
How to
post your code.
