How can I get each Polygon in a region?
markc0826
Message 1 of 9
markc0826
Dear all..
Like as the image, there are dividing lines(yellow) in a region (red). How can I get each type of polygon with VBA?
Thanks for helping..
Replies (8)
Message 2 of 9
Ed__Jobe
Are they actual lwpolygon entities or just areas formed by intersecting lines?
Ed
How to post your code.
Message 3 of 9
markc0826
just areas formed by intersecting lines !!
Message 4 of 9
arcticad
a lot of math and using intersectwith. There isn't a built in function to do this.
(defun botsbuildbots() (botsbuildbots))
Message 5 of 9
markc0826
Could you give me some suggestions or ideas to do that...Smiley Indifferent
Message 6 of 9
Hallex
Start from this one , but keep in mind
you'll get many duplicates
Option Explicit
'make sure under "Tools|Options|General" you select "Break on Unhandled Errors" button
Public Sub CreateAllPolygons()
Dim oCirc As AcadCircle
Dim oSset As AcadSelectionSet
Dim gap As Double
Dim zp1 As Variant
Dim zp2 As Variant
For Each oSset In ThisDrawing.SelectionSets
If oSset.Name = "$Lines$" Then
ThisDrawing.SelectionSets("$Lines$").Delete
Exit For
Next
ThisDrawing.SelectionSets.Add ("$Lines$")
Set oSset = ThisDrawing.SelectionSets("$Lines$")
Dim ftype(0) As Integer
Dim fdata(0) As Variant
ftype(0) = 0: fdata(0) = "line"
gap = ThisDrawing.Utility.GetDistance(, vbLf & "Pick distance of smallest dimension of the cell:")
zp1 = ThisDrawing.Utility.GetPoint(, vbLf & "Lower left point of selection area:")
zp2 = ThisDrawing.Utility.GetCorner(zp1, vbLf & "Upper right point of selection area:")
ZoomWindow zp1, zp2
ThisDrawing.Utility.Prompt vbLf & vbTab & "Select all lines:"
oSset.SelectOnScreen ftype, fdata
Dim n As Integer
Dim points() As Double
n = -1
Dim i As Integer
Dim j As Integer
Dim k As Integer
Dim pts() As Double
For i = 0 To oSset.Count - 2
For j = 0 To oSset.Count - 1
pts = oSset(i).IntersectWith(oSset(j), acExtendNone)
If LBound(pts) <> -1 Then
For k = 0 To UBound(pts)
n = n + 1
If n = 0 Then
ReDim points(0)
Else
ReDim Preserve points(n)
points(n) = CDbl(pts(k))
Next
Next
Next
ThisDrawing.StartUndoMark
ThisDrawing.SetVariable "celweight", 50
ThisDrawing.SetVariable "cecolor", "4"
gap = gap / 2
For i = 0 To UBound(points) - 2 Step 3
Dim p(2) As Double
p(0) = points(i)
p(1) = points(i + 1)
p(2) = points(i + 2)
Dim inspt As Variant
inspt = ThisDrawing.Utility.TranslateCoordinates(p, acWorld, acUCS, False)
Dim pstr As String
On Error Resume Next
pstr = Replace(CStr(inspt(0) + gap), ",", ".") & "," & Replace(CStr(inspt(1) + gap), ",", ".")
ThisDrawing.SendCommand Chr(3) & Chr(3) & "-boundary " & pstr & vbCr & vbCr
pstr = Replace(CStr(inspt(0) - gap), ",", ".") & "," & Replace(CStr(inspt(1) + gap), ",", ".")
pstr = Replace(CStr(inspt(0) - gap), ",", ".") & "," & Replace(CStr(inspt(1) - gap), ",", ".")
pstr = Replace(CStr(inspt(0) + gap), ",", ".") & "," & Replace(CStr(inspt(1) - gap), ",", ".")
Next
ThisDrawing.EndUndoMark
End Sub
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 7 of 9
Hallex
Here is released code without duplicate contours
Option Explicit
Dim gap As Double
Dim zp1 As Variant
Dim zp2 As Variant
Exit For
Next
ZoomWindow zp1, zp2
Dim n As Integer
n = -1
Dim i As Integer
Dim j As Integer
Dim k As Integer
Dim pts() As Double
n = n + 1
If n = 0 Then
ReDim points(0)
Else
Next
Next
Next
gap = gap / 2
Dim p(2) As Double
p(0) = points(i)
Dim pstr As String
Next
' Important:
' After the overkill window occurs uncheck all of the checkboxes inside
ThisDrawing.SendCommand Chr(3) & Chr(3) & "_overkill " & "pause" & vbCr
End Sub
 Make sure you've select the same area after
all polygons were created to run OVERKILL command
~'J'~
Message 8 of 9
markc0826
What a wonderful solutionSmiley Surprised...It's worked
I think I'll spend lot of time to study it.
Thank you very very very much for helping..Smiley Happy
Message 9 of 9
Hallex
This is a crap code, but I could not find an another way
You're welcome, though
Spoiler
~'J'~
