Here is released code without duplicate contours
Option Explicit
'make sure under "Tools|Options|General" you select "Break on Unhandled Errors" button
Public Sub CreateAllPolygons()
Dim oCirc As AcadCircle
Dim oSset As AcadSelectionSet
Dim gap As Double
Dim zp1 As Variant
Dim zp2 As Variant
For Each oSset In ThisDrawing.SelectionSets
If oSset.Name = "$Lines$" Then
ThisDrawing.SelectionSets("$Lines$").Delete
Exit For
End If
Next
ThisDrawing.SelectionSets.Add ("$Lines$")
Set oSset = ThisDrawing.SelectionSets("$Lines$")
Dim ftype(0) As Integer
Dim fdata(0) As Variant
ftype(0) = 0: fdata(0) = "line"
gap = ThisDrawing.Utility.GetDistance(, vbLf & "Pick distance of smallest dimension of the cell:")
zp1 = ThisDrawing.Utility.GetPoint(, vbLf & "Lower left point of selection area:")
zp2 = ThisDrawing.Utility.GetCorner(zp1, vbLf & "Upper right point of selection area:")
ZoomWindow zp1, zp2
ThisDrawing.Utility.Prompt vbLf & vbTab & "Select all lines:"
oSset.SelectOnScreen ftype, fdata
Dim n As Integer
Dim points() As Double
n = -1
Dim i As Integer
Dim j As Integer
Dim k As Integer
Dim pts() As Double
For i = 0 To oSset.Count - 2
For j = 0 To oSset.Count - 1
pts = oSset(i).IntersectWith(oSset(j), acExtendNone)
If LBound(pts) <> -1 Then
For k = 0 To UBound(pts)
n = n + 1
If n = 0 Then
ReDim points(0)
Else
ReDim Preserve points(n)
End If
points(n) = CDbl(pts(k))
Next
End If
Next
Next
ThisDrawing.StartUndoMark
ThisDrawing.SetVariable "celweight", 50
ThisDrawing.SetVariable "cecolor", "4"
gap = gap / 2
For i = 0 To UBound(points) - 2 Step 3
Dim p(2) As Double
p(0) = points(i)
p(1) = points(i + 1)
p(2) = points(i + 2)
Dim inspt As Variant
inspt = ThisDrawing.Utility.TranslateCoordinates(p, acWorld, acUCS, False)
Dim pstr As String
On Error Resume Next
pstr = Replace(CStr(inspt(0) + gap), ",", ".") & "," & Replace(CStr(inspt(1) + gap), ",", ".")
ThisDrawing.SendCommand Chr(3) & Chr(3) & "-boundary " & pstr & vbCr & vbCr
pstr = Replace(CStr(inspt(0) - gap), ",", ".") & "," & Replace(CStr(inspt(1) + gap), ",", ".")
pstr = Replace(CStr(inspt(0) - gap), ",", ".") & "," & Replace(CStr(inspt(1) - gap), ",", ".")
pstr = Replace(CStr(inspt(0) + gap), ",", ".") & "," & Replace(CStr(inspt(1) - gap), ",", ".")
Next
' Important:
' After the overkill window occurs uncheck all of the checkboxes inside
ThisDrawing.SendCommand Chr(3) & Chr(3) & "_overkill " & "pause" & vbCr
ThisDrawing.EndUndoMark
End Sub
Make sure you've select the same area after
all polygons were created to run OVERKILL command
~'J'~
