Getstring with default value
seabrahenrique
seabrahenrique
Hello guys!
I know that question may sound by a elemental point, but i can't finded a answer here with a vba...
So, how can i do someting like that: https://forums.autodesk.com/t5/net/set-a-default-answer-to-editor-getstring/td-p/5677604 in a VBA code?
Thanks in adance!
Ed__Jobe
VBA has the functions GetSetting and SaveSetting. They save values to the registry. This enables you to save an option that you can recover the next time the command is run.
GetSetting Function
Returns a key setting value from an application's entry in the Windows registry or (on the Macintosh) information in the application’s initialization file.
Syntax
GetSetting(appname, section, key[, default])
The GetSetting function syntax has these named arguments:
Part Description
appname Required. String expression containing the name of the application or project whose key setting is requested. On the Macintosh, this is the filename of the initialization file in the Preferences folder in the System folder.
section Required. String expression containing the name of the section where the key setting is found.
key Required. String expression containing the name of the key setting to return.
default Optional. Expression containing the value to return if no value is set in the key setting. If omitted, default is assumed to be a zero-length string ("").
Remarks
If any of the items named in the GetSetting arguments do not exist, GetSetting returns the value of default.
Alternatively, you can just phrase your GetString prompt to include a default value. Just use the standard AutoCAD prompt string format. The structure for a prompt is "text message\ : \[optional keywords]", e.g.  You should also use GetKeyword to limit user input and make it easier for them to enter a choice.
Dim strChoice As String
'use GetKeyword here to se up your options.
strChoice = ThisDrawing.Utilty.GetString(False, "Enter your choice : [default/option1/option2] ")
Case Select strChoice
  case = vbCr or "default"
    'perform default action
  case = "option1"
  case = "option2"
End Select
'Combined with GetSetting you could have:
strChoice = Getsetting("MyApp","MyCommands","Command1")
If strChoice = "" Then strChoice = "default"
strChoice = ThisDrawing.Utilty.GetString(False, "Enter your choice : [" & strChoice & "/option1/option2] ")
    SaveSetting("MyApp","MyCommands", "Command1", "default"
  case = "option1"
    'perform option1 action
    SaveSetting("MyApp","MyCommands", "Command1", "option1"
  case = "option2"
    'perform option2 action
    SaveSetting("MyApp","MyCommands", "Command1", "option2"
End Select
Ed
How to post your code.
seabrahenrique
Thanks for the answer @Ed__Jobe! I'll test soon.
