Autodesk Inventor 2022 VBA - Set Part Chrome or Set Part Colour
isocam
isocam
Can anybody help?
Please see the two attached macro files.
Can anybody create a simple extruded part and test each macro?
The first should change the part colour to chrome. My graphics card is not suitable to show chromed parts properly.
Does it actually change the part to a chromed finish???
Secondly, Please try the second macro to change the part colour to RGB
I cannot get this one to work, I am using Inventor 2022. Does anybody know what is wrong with the macro?
Many thanks in advance!!
Darren
Ed__Jobe
Some of your logic is not good programming practice. This topic has a solution. But it is in iLogic. It's very similar to VBA though.
Ed
How to post your code.
Ed__Jobe
Here's a tested vba version for setting chrome.
Public Function SetPartChrome()
    Dim oPDoc As PartDocument
    Set oPDoc = ThisDocument
    Dim localAsset As Asset
    Dim assetLib As AssetLibrary
    Dim libAsset As Asset
    On Error Resume Next
    Set localAsset = oPDoc.MaterialAssets.Item("Chrome - Polished")
    If Err Then
        On Error GoTo 0
        Set assetLib = ThisApplication.AssetLibraries.Item("Autodesk Material Library")
        Set libAsset = assetLib.AppearanceAssets.Item("Chrome - Polished")
        Set localAsset = libAsset.CopyTo(oPDoc)
    ThisDocument.ActiveMaterial = localAsset
    'When you change the material to chrome,
    'the appearance is automatically set to Default.
    'Uncomment the section below if you also want to override to chrome.
'    On Error Resume Next
'    Set localAsset = oPDoc.Assets.Item("Chrome - Polished")
'    If Err Then
'        On Error GoTo 0
'        Set assetLib = ThisApplication.AssetLibraries.Item("Autodesk Appearance Library")
'        Set libAsset = assetLib.AppearanceAssets.Item("Chrome - Polished")
'        Set localAsset = libAsset.CopyTo(oPDoc)
'    End If
'    ThisDocument.ActiveAppearance = localAsset
End Function
Ed
