The editor class has a method called GetString which prompts the user for a string value via AutoCAD's command prompt. I call it in this wrapper method:
public static string PromptUserForString(string message = "Enter a string: ", string defaultAnswer = "")
return _editor.GetString("\n" + message).StringResult;
The argument message becomes the message the user sees when prompted for a string. How do I set it up so that the value of default answer is automatically set to be the answer so that if the user hits enter right away that becomes the value like in the screen shot below
So 1 is automatically typed as an answer meaning the user can either hit enter for the value of 1 or change 1 to whatever non-default answer they want
