Set a Default Answer to Editor.GetString()
The editor class has a method called GetString which prompts the user for a string value via AutoCAD's command prompt. I call it in this wrapper method:
public static string PromptUserForString(string message = "Enter a string: ", string defaultAnswer = "")
    return _editor.GetString("\n" + message).StringResult;
The argument message becomes the message the user sees when prompted for a string. How do I set it up so that the value of default answer is automatically set to be the answer so that if the user hits enter right away that becomes the value like in the screen shot below
So 1 is automatically typed as an answer meaning the user can either hit enter for the value of 1 or change 1 to whatever non-default answer they want
norman.yuan
Editor.GetString() has an overload that takes PromptStringOptions as input parameter, so that you can define your PromptStringOptions to gain more controls on how Editor.GetString() works.
In your case, you can look at PromptStringOptions.DefaultValue and/or PromptStringOptions.Keywords.
HTH
Norman Yuan
Drive CAD With Code
zrobert
Something like this...
var pso = new PromptStringOptions("\nEnter a string:");
pso.DefaultValue = "default";
var psr = editor.GetString(pso);
if (psr.Status == PromptStatus.OK)
        // do job ...
Exactly what I needed, thanks!
