generate lines from excel data
Message 1 of 8
i want to generate lines from excel data in autocad by directly linking excel data to autocad. may be vba will help me in this. i know that can be done by making csv file and then saving that in scr format. but i want to do it form microsoft excel data directly. CAN YOU HELP ME??
Replies (7)
Message 2 of 8
A line is defined by at least two points. Store the points in contiguous
rows, for example X in column B and Y in column C. Read these coordinates
from the Excel sheet, each X and Y will be used to create a point in a
variant varaible, and then use the points to create the lines.
Gilles Plante
wrote in message news:5453993@discussion.autodesk.com...
Message 3 of 8
Gilles,
With autocad open and vaules in excel cells a1,b1,c1
This should draw a circle.
 not sure where I got it from
Sub drawcircle()
Dim oAcadApp As AcadApplication
Dim oAcadDoc As AcadDocument
Dim oHatch As AcadHatch
Dim oEntArray(0 To 0) As AcadEntity
Dim dCenterPoint(0 To 2) As Double
Dim dRadius As Double
Set oAcadApp = GetObject(,
"Autocad.application")
Set oAcadDoc = oAcadApp.ActiveDocument
AppActivate oAcadApp.Caption
dCenterPoint(0) = ThisWorkbook.ActiveSheet.Cells(1,
1).Value
dCenterPoint(1) = ThisWorkbook.ActiveSheet.Cells(1,
2).Value
dCenterPoint(2) = 0#
dRadius = ThisWorkbook.ActiveSheet.Cells(1,
3).Value
Set oEntArray(0) =
oAcadDoc.ModelSpace.AddCircle(dCenterPoint, dRadius)
Set oHatch = oAcadDoc.ModelSpace.AddHatch(0, "Solid",
True)
With oHatch
.AppendOuterLoop oEntArray
End With
End Sub
john coon
create the lines.
Gilles Plante
<subodhsapkota> wrote in
message
size=2>news:5453993@discussion.autodesk.com
size=2>...
linking
can be
want to do
ME??
Message 4 of 8
John,
you can draw anything you wish with values
from "outside". These values can be anything you mean they are.
From "Developper HELP" under Help:
RetVal = object.AddLine(StartPoint, EndPoint)
Object
href="mk:@MSITStore:J:\Program%20Files\AutoCAD%202007\help\acadauto.chm::/idh_modelspace_collection...
href="mk:@MSITStore:J:\Program%20Files\AutoCAD%202007\help\acadauto.chm::/idh_paperspace_collection...
href="mk:@MSITStore:J:\Program%20Files\AutoCAD%202007\help\acadauto.chm::/idh_block_object.htm">Blo...
The
object or objects this method applies to.
StartPoint
Variant (three-element array of doubles);
input-only
The 3D WCS coordinates specifying the line start point.
EndPoint
input-only
The 3D WCS coordinates specifying the line endpoint.
RetVal
href="mk:@MSITStore:J:\Program%20Files\AutoCAD%202007\help\acadauto.chm::/idh_line_object.htm">Line
object
The newly created Line object.
Gilles Plante
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Gilles,
a1,b1,c1
Sub drawcircle()
1).Value
2).Value
3).Value
Set oEntArray(0) =
"Solid", True)
With oHatch
End With
End Sub
john coon
Gilles
Plante
<subodhsapkota> wrote in message
href="news:5453993@discussion.autodesk.com">
size=2>...
linking
that can be
but i want to do
ME??
Message 5 of 8
Gilles,
Thanks for the info, I guess I clicked on the work
post. the data was for subodhsapkota.
I have been looking for ways to draw complete
drawings or at least details with excel but have yet to find very many samples
other than like the one I supplied.
I need to find better or more complete sample to be
able to see how I can change my of my existing routines and offer them in
excel.
I've created a lot of routines that run directly in
AutoCAD but I think offering some of these tools driven from excel would
add a lot of power and might open my eyes to newer ways of generating
drawing content.
Have a great day.
John
John,
Object
href="mk:@MSITStore:J:\Program%20Files\AutoCAD%202007\help\acadauto.chm::/idh_modelspace_collecti...
href="mk:@MSITStore:J:\Program%20Files\AutoCAD%202007\help\acadauto.chm::/idh_paperspace_collecti...
href="mk:@MSITStore:J:\Program%20Files\AutoCAD%202007\help\acadauto.chm::/idh_block_object.htm">B...
The
StartPoint
input-only
EndPoint
input-only
RetVal
href="mk:@MSITStore:J:\Program%20Files\AutoCAD%202007\help\acadauto.chm::/idh_line_object.htm">Li...
object
Gilles Plante
Gilles,
a1,b1,c1
This should draw a
circle.
Sub drawcircle()
dCenterPoint(0) =
ThisWorkbook.ActiveSheet.Cells(1, 1).Value
dCenterPoint(1) =
ThisWorkbook.ActiveSheet.Cells(1, 2).Value
3).Value
Set oEntArray(0) =
"Solid", True)
With oHatch
End With
End Sub
john coon
Gilles
Plante
size=2>...
directly linking
i know that can be
HELP ME??
Message 6 of 8
You can add Microsoft Office Spreadsheet control into VBA editor.
and use that control to running excel spreadsheet.
Message 7 of 8
I can give this VBA macro to you, leave your e-mail address here.
Message 8 of 8
Here is an simple example how it
must be to do
A2005, MS Excel 2003
Change references to AutoCAD library
by your current version
Open AutoCAD then minimize its window
but do not close it
Open this Excel file, then select region
all the 4 columns but without headers
and hit "Draw Lines" button
Hth
~'J'~
