Attribute Position
Attribute Position
Attribute Position
Assuming an attribute position is not locked a user may move it to a more
suitable location.
If ATTSYNC is used then the attributes revert to their default positions.
How can I read the amount the attribute has been offset?
I can get the attribute reference insertion point and compare it with the
block reference insertion point.
But there appears to be no way to do the same for the block defeinition, or
is there another way?
Dave Preston
Technical Dev. Engineer
C A Design Services Limited
Address: Design Centre, Hewett Rd, Gapton Hall,
GREAT YARMOUTH,
Norfolk 31 0NN,
Tel: 01493 440444,
Fax: 01493 442480,
E-Mail: dpreston@cadesignservices.co.uk,
Web Site: www.cadesignservices.co.uk,
Registered in England No. 1595687
This e-mail and any attached files is confidential and intended for the
addressee(s) only. It may contain privileged and confidential information,
and may not be disclosed to anyone else. Unauthorised recipients are
requested to preserve this confidentiality by deleting the original and to
advise the sender immediately of any mistakes in transmission. Internet
communications are not secure and therefore C A Design Services Limited does
not accept any legal responsibility for the contents of this message, and
the message and files are opened at the risk of the recipient. Unless
otherwise specifically stated any views or opinions are solely those of the
author and do not represent those of C A De
I've sussed it but if anyone knows an easier way?
I have to read through each entity in the block definition and if an
attribute read it's insertion point, then compare it's tag string with the
block reference tag string and do the claulations.
Dave Preston
GREAT YARMOUTH,
Norfolk 31 0NN,
Tel: 01493 440444,
Fax: 01493 442480,
"Dave Preston" wrote in message
news:5453957@discussion.autodesk.com...
suitable location.
Dave Preston
GREAT YARMOUTH,
Norfolk 31 0NN,
Tel: 01493 440444,
Fax: 01493 442480,
