Drawing dimensions on dynamic blocks not updating after Excel VBA updates block properties
s.mahmoodV7HPM
s.mahmoodV7HPM
Hi all,
I am updating dynamic block in a drawing and it is working fine, problem I am facing that dimensions are not adjusting to new size.
If I double click manually on the block (before block definition window appears) dimensions are updated to new size of block.
Any idea I can get it done through automatically whenever block size is changed via some setting or adding something to my code.
I have tried acadApp.Application.Update and it does the update but doesn't help with dimensions.
best regards,
Zee
Ed__Jobe
Nice pictures... we need code. And a sample of your dwg to work with. Provide as much info as possible when asking for help.
You might look at this thread, since it is similar.
Ed
How to post your code.
s.mahmoodV7HPM
Hi Ed,
thanks for guiding me to right direction which led me a way to get this solved.
Apologies that my post was not up to standard.
Adding this to my vba code solved it for me
acadDoc.SendCommand "Regen3" & vbCr
best regards,
sam
