Action Macro is giving an executetool failure
MHerbert!
MHerbert!
I have made 452 action macros and placed them on our sever to use on other computers in our department via VBA.
All of them work on my computer, but, when I tried using them on another computer, I received an executetool failure message.  In the macros I use the tool palette blocks and place them in in the drawing.  Most of them are dynamic blocks and the executetool places them at "0,0" and changes the visibility of the block.
Can someone help me stop the failure message?
mherbert
aachiney
Does the other machine has the same version of AutoCAD which you have?
Does the other machine support VBA?
And above all, what kind of message are you getting?
Regards
MHerbert!
1. All our machines run the same version of AutoCAD (2021)
2. All our machines support VBA
3. An error occurred with the 001AA-00 action macro during playback.
What do you want to do?
The command returned an error message:
Command Failed: EXECUTETOOL
Specify tool palette to display or [palette Group]: Title Block
Command: 001AA-00
EXECUTETOOL
Continue Playback
Stop Playback
MHerbert!
Command:  001AA-00
EXECUTETOOL
Continue Playback
Stop Playback
MHerbert!
So, is there a solution?
