Find out if polyline object include Arc and get Arc points
jalal.mousa
jalal.mousa
Hi There
i am trying to get Coordinates of polyline to be used later for selection set
but when i have arc it only get me start point and end point of an arc
i am using point array to get all object within selection set but i am missing all objects inside Arc/Circle portion
how i can adjust code to include Arcs within point array
Set Flooringshape1 = Room
Test = True
If TypeOf Flooringshape1 Is AcadCircle Then
Set Floorcircle = Flooringshape
circleCen(0) = Floorcircle.center(0)
circleCen(1) = Floorcircle.center(1)
circleRad = Floorcircle.radius
 ElseIf TypeOf Flooringshape1 Is AcadLWPolyline Then
 If Flooringshape1.closed = True Then
            Set PL = Flooringshape1
           sarea = PL.area
           Slength = PL.length
          ReDim points(UBound(PL.Coordinates) + (UBound(PL.Coordinates) + 1) / 2 + 3) As Double
          ReDim savepoints(UBound(PL.Coordinates) + (UBound(PL.Coordinates) + 1) / 2 + 3) As Double
         Dim Roompoints() As Double
          ''dim v As Variant
          ' V is the Room 2D coordinates
          v = PL.Coordinates
        Dim i As Integer
        L = UBound(v)
        index = 0
 ' Change 2D Coordinates to 3D Z=0
            For i = 0 To UBound(v) Step 2
                points(index) = v(i)
                points(index + 1) = v(i + 1)
                points(index + 2) = 0
                index = index + 3
            Next
        points(index) = points(0)
        points(index + 1) = points(1)
        '3D Coordinates
        savepoints = points
Ed__Jobe
It seems that you are trying to flatten the plines. LWPolylines are 2D objects, i.e. the coordinates don't have a Z value. From Help:
"LightweightPolyline object: The variant is an array of 2D points in OCS."
You can simply use the FLATTEN command to move them to the WCS. If the points are not in the WCS, you need to transform the coordinates from the OCS to WCS or from the current UCS to WCS.
Anyway, the "arcs" in a pline are lines with a bulge factor applied. They do not have a center point. You would need to get the endpoints and using trigonometry, use the bulge factor to get the center point. If you search this forum for "bulge", there are some previous posts. Here's a thread at AUGI that might help.
Ed
How to post your code.
