doesnot hide userfrom1 how to solve this problem
jaimuthu
jaimuthu
Private Sub CommandButton1_Click()
Dim FN As String
Dim LN As Double
FN = TextBox3.Value
LN = TextBox4.Value
ThisDrawing.SendCommand "tk" & Chr(10) & FN & Chr(10) & LN & Chr(10)
UserForm1.Hide
TextBox3.Value = Clear
TextBox4.Value = Clear
'TextBox3.SetFocus
End Sub
Private Sub Frame1_Click()
End Sub
Private Sub TextBox1_Change()
ThisDrawing.SetVariable "USERS1", TextBox1.Value
End Sub
Private Sub TextBox2_Change()
ThisDrawing.SetVariable "USERS2", TextBox2.Value
End Sub
Private Sub TextBox3_Change()
End Sub
Ed__Jobe
Try "me.Hide". Also note that the SendCommand method will run after all your vba code runs.
Ed
How to post your code.
jaimuthu
me.hide  not work
Ed__Jobe
I assume that the code below is in the userform. If so, there is no other way to hide the form. If you post your dvb, I might be able to take a look at it. If the upload won't let you post a dvb, then zip it first.
Dim FN As String
Dim LN As Double
FN = TextBox3.Value
LN = TextBox4.Value
'UserForm1.Hide
Me.Hide
'TextBox3.SetFocus
Ed
