ADD TEXT NOTE UNDER THE DIMENSION LINE
buitrongcuongypbn2000
Hi everyone. I am having a problem when export drawing from Inventor to Autocad. The dimensions have the text under the dimensions line breaking the line as picture above.
I need a VBA code to fix this problem.
Could you help me?
Thanks for your attention!
Ed__Jobe
Can you post a sample dwg?
Ed
How to post your code.
Dear Ed.Jobe,
This is an example file you needs.
Thanks.
Ed__Jobe
Before you can code a solution, you have to figure out what is causing the condition. I found that if you right click on the dim and select Remove Style Overrides, then the dim line goes through. So there is an override setting causing the problem. I ran out of time to figure it out.
Also, the text override is "\fISOCPEUR|b0|i0;\H175.0000;<>\P\fISOCPEUR|b0|i0;\H175.0000;PART 6". The \P just inserts a return or new paragraph. If you change it to \X, it puts the second line below the dim line. So it would look like,
"\fISOCPEUR|b0|i0;\H175.0000;<>\X\fISOCPEUR|b0|i0;\H175.0000;PART 6".
It might help if your Inventor file used a style with these properties instead of using overrides in the first place.
Ed
