Exporting all abjects in the model space to a BMP file
jmsotoSZEGT
jmsotoSZEGT
Community Visitor
Community Visitor
I was hoping someone could help me with a small pice of code. I want to export all all visible objects in the model space to a BMP file. So far I am able to (via VBA code) select all visible objects. However I cant seem to set a "selection set" from the selected objects, which I undestand I need in order to use the export command in Autocad VBA. Any help would be appreciated. Thank you.
norman.yuan
How do you "(via VBA code) select all visible object"? Shouldn't they be in a selectionset already, if you have them "selected" via your code?
You need to post your code to show how you "select all visible object".
Norman Yuan
Drive CAD With Code
jmsotoSZEGT
Community Visitor
Community Visitor
Norman ... thanks for your reply. I finally got it sorted out. Thanks for taking the time.
