Creating UCS from line
Jan-Brauer
Jan-Brauer
Can someone help me to create a UCS from a given line (should ultimately only use the x-direction so it is subordinate to how it is twisted around the x-axis.)
I have a problem switching to  a new UCS.
I have a given line, for it I find the starting point and the end point,
then I find a point perpendicular to the line from the starting point,
I have tried 2 methods:
    the first was a vector calculation in vba,
    the second used thisdrawing.utilitu.polarpunkt.
Then i used thisdrawing.ucs.add…..
With both calculations, AutoCAD came up with an error that the 3 points do not form a right angle.
I have tried to calculate both as points and as vectors
I have then had the program draw lines between the points.
It is now possible to switch UCS from the command line by pointing to the 3 points.
I therefore tried to use Sendcommand.
There is no error using this metode, but the generated UCS is completely wrong.
What do i do wrong 😞
Ed__Jobe
Show your code so we can help you.
Ed
How to post your code.
Ray-Sync
I use this:
Sub coor_relat()
Dim myucs As AcadUCS
Dim pt As Variant, pt1 As Variant, pt2 As Variant
Dim l As AcadLine
Dim pi As Double
pi = 4 * Atn(1)
pt = ThisDrawing.Utility.GetPoint(, "clic 1 point")
pt1 = ThisDrawing.Utility.GetPoint(, "clic 2 point")
Set l = ThisDrawing.ModelSpace.AddLine(pt, pt1)
pt2 = ThisDrawing.Utility.PolarPoint(pt, l.Angle + (pi / 2), 1)
Set myucs = ThisDrawing.UserCoordinateSystems.Add(pt, pt1, pt2, "UCS1")
ThisDrawing.ActiveUCS = myucs
ThisDrawing.ActiveViewport.UCSIconOn = True
ThisDrawing.ActiveViewport.UCSIconAtOrigin = True
ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
l.Delete
End Sub
jefferson
