Get Block Elements Properties Without Attributes
I would like to know, if it is possible to access to a block, without attributes, to get a polyline length, for example.
If it’s a dynamic block, I know that I can access at those Properties (“AllowedValues”,”Description”,”PropertyName”,”ReadOnly”,”show”, UnitsType” and “Value”). But I was expecting it has a property like “Element” or “item” that gives me a list of elements inside the block, that I can access and get the information that I want.
Thanks in advance.
BestRegards
norman.yuan
The term "block" you used here is block reference (AcadBlockReference), which does not have "elements" in it (except for attributes -AcadAttributeReference), it is just a REFERENCE of a block definition (AcadBlock), or an "image" of a block definition being placed in Model/PaperSpace. To know the block elements' properties, you need to go to the block definition.
Following code shows how to do it, assume you let user to select a block (block reference);
Dim ent as AcadEntity
Dim pt As Variant
Dim blkRef As AcadBlockRefernece
Dim blkDef As AcadBlock
Dim blkName As String
Dim line As AcadLine
Dim circel As AcadCircle
ThisDrawing.Utility.GetEntity ent, pt, vbCr & "Select a Block:"
If TypeOf ent Is AcadBlockReference Then
  Set blkRef=ent
  blkName=blkRef.Name
  '' Get the block definition of selected block reference
  Set blkDef=ThisDrawing.Blocks(blkName)
  '' access each element in the block definition
  For Each ent in blkDef
    If TypeOf ent IsAcadLine Then
      Set line=ent
      Msgbox "Line in block: Length->" & line.Length
    ElseIf TypeOf ent Is AcadCircle Then
      Set circle=ent
      MsgBox "Circle in block: Radius=>" & circle.Radius
    ElseIf ....
  Next
End Id
Norman Yuan
Drive CAD With Code
