Insert Block event
Insert Block event
grobnik
Insert Block event
grobnik
Hi to everybody,
is there a way by VBA to trap the inserting block event ? I need to trap the event, and later identify the block inserted name for doing some other thing.
Thank you
grobnik
Sorry If AutoReply
I tried this simple code, and I inserted a block with attributes.
Private Sub AcadDocument_ObjectAdded(ByVal Object As Object)
    Debug.Print "PIPPI"
End Sub
The event has been trapped but I'm not able to evaluate the  Type Of Object inserted, see image below
Ed__Jobe
Private Sub AcadDocument_ObjectAdded(ByVal Object as Object)
    If TypeOf Object Is AcadBlockReference Then
        'Save block.Name or ID, etc.
        Dim blkRef as AcadBlockReference
        Set blkRef = Object
        SaveSetting appname, section, key, blkRef.Name
End Sub
Ed
How to post your code.
grobnik
Thank you Ed,
could you help me understanding the reasons because in my previous code the object count was zero, and now it's trapped ?
Thank you
Ed__Jobe
It's simply that when you took your screenshot, the object type was a dictionary, not a blockref. This event is going to fire for every single object that gets added to the database, not just graphical entities.
Ed
