Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Change VisualStyle of Viewport to Hidden
jeremye86
jeremye86
Is it possible to change the Visual Style of Viewport to Hidden.  I am creating the viewport with the following code
    'CREATE THE VIEWPORTS
    center(0) = 12.745: center(1) = 5.9676
    Set pviewportObj = acadDoc.PaperSpace.AddPViewport(center, 8.2903, ViewPortHtNozzBaseplate)
    pviewportObj.Layer = "viewport"
    pviewportObj.Display True
    acadDoc.MSpace = True
    acadDoc.Application.ZoomWindow minExtBlockBasePlate, maxExtBlockBasePlate
    acadDoc.MSpace = False
    pviewportObj.DisplayLocked = True
  • VBA
lena.talkhina
Hello @jeremye86 !
Great to see you on Autodesk Community forums.
I see nobody reacted on your request. Did you find a solution so far?
Don't hesitate to update info in this thread to find more support from community members.
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
jeremye86
Yes I found a solution
lena.talkhina
Thanks for the update @jeremye86 !
It would be wonderful if you can share the solution with community so we help members to find answers faster.
jeremye86
Here is the solution.  I just used the property VisualStyle  and  ShadePlot.  I just had to do trial and error to find the correct number code.
center(0) = 4.2913: center(1) = 5.5097
Set pviewportObj = acadDoc.PaperSpace.AddPViewport(center, ViewPortWidthNozzSideTopV, ViewPortHtNozzSideTopV)
pviewportObj.VisualStyle = 4
pviewportObj.ShadePlot = 3
acadDoc.Application.ZoomWindow minExtBlockNozzSideV, maxExtBlockNozzTopV
acadDoc.Regen acActiveViewport
lena.talkhina
Thank you @jeremye86 !
I am sure other community members appreciate it.
