Copy Pasting object from one drawing file to another
Message 1 of 28
Hallo everyone!
I have a problem regarding Autocad drawing with VBA coding. I am trying to copy paste an object (for ex. a circle) from one dwg file to another dwg file via VBA coding. I cant write the code for it. Is there any way to do it besides Wblock command specially when I want to copy paste objects from multiple dwg files?
Please help me...
Replies (27)
Message 21 of 28
So I looked in to SelectionSet.Select as you suggested, thanks. And I wrote up some code for what I'm trying to achieve (selecting all to then copy).
I've resolved errors and refined it to this point - looks good to me but I'm getting "automation error" on "Set ssetObj = ThisDrawing.SelectionSets.Add("SSET")"
Option Explicit
Public Sub CopyEntities()
    ''Set the source drawing
    Dim curDwg As AcadDocument
    Dim d As AcadDocument
    For Each d In AcadApplication.Documents
        If UCase(d.Name) = "DRAWING1.DWG" Then
            Set curDwg = d
            Exit For
    Next
    If curDwg Is Nothing Then
        MsgBox "Cannot find source drawing ""Drawing1.dwg"""
        Exit Sub
    Dim entities() As Object
    entities = SelectAll(curDwg)
    ''Open a new drawing
    Dim newDwg As AcadDocument
    Set newDwg = AcadApplication.Documents.Add()
    ''Copy entities from source drawing to new drawing
    curDwg.CopyObjects entities, newDwg.ModelSpace
End Sub
Private Function SelectAll()
Dim ThisDrawing As AcadDocument
Set ThisDrawing = AutoCAD.ActiveDocument
Dim mode As Integer
Dim ssetObj As AcadSelectionSet
Dim FilterType As Integer
Dim FilterData As Variant
FilterType = 67
FilterData = 0
'object.Select Mode [, Point1] [, Point2] [, FilterType, FilterData]
ssetObj.Select acSelectionSetAll, , , FilterType, FilterData
End Function
Any thoughts on what's going wrong here? Cheers.
Message 22 of 28
norman.yuan
The error lies in your function SelectAll: there are a few things wrong:
1. Firstly, you did not declare what the Type the function returns, which is allowed while not being good practice, thus, the function would return Variant type. However, with this function you DID not actually return anything; that is, you need to hate a line of code before "End Function", something like
   SelectAll = ....
End Function
So, your function returns an empty value of Variant type. Therefore, your main code, after the Function is called, even assume you do not have other error in SelectAll(), obviously will not work, because
entities = SelectAll()
get you nothing in the "entities" object array.
2. About the error you get at
Set ssetObj = ThsiDrawing.SelectionSet.Add("SSET")
I bet when you run the code first time, this line works OK (but not the next line, as aforementioned), because the drawing already has a SelectionSet, names as "SSET" due to the previous run, thus the error. When creating a AcadSelectionSet, ALWAYS test if there is one with the same name allready exists; if yes, either re-use the existing one, or create with different name.
a. you can:
Dim ss As AcadSelectionSet
For Each ss in ThisDrawing.SelectionSets
  if Ucase(ss.Name)="SSET" Then
    Set ssetObj=ss
    ssetObj.Clear
    Exit For
Next
If ssetObj Is Noting Then
  Set ssetObj = ThisDrawing.SelectioNSets.Add("SSET")
b. you can also use error catching to make your code a bit simple, like this:
On Error Resume Next
'' Set it to existing one
Set ssetObj = ThisDrawing.SelectionSet("SSET")
'' If no existing found, error is raised
If err.Number <> 0 Then
On Error GoTo 0
3. Even you actually return the selectionset (ssetObj) with a line of code in end SelectionAll(), like
  ssetObj,Select acSelectionSetAll......
  Set SelectAll= ssetObj
End Function
The code STILL DOES NOT work, because CopyFrom expect an AcadObject array, not an AcadSelectionSet. You MUST convert the AcadSelectionSet to object array.
4. If your code is meant to run with AutoCAD VBA, you DO NOT declear a variable "ThisDrawing", which is AutoCAD VBA' reserved object
Anyway, Following should be how the SelectAll() function look like (not tested, just off my head):
Private Function SelectAll() As Variant
 Dim mode As Integer
For Each ss In ThisDrawing.SelectionSets
If UCase(ss.Name)="SSET" Then
Set ssetObj = ss
ssetObj.Clear
Exit For
Next
If ssetObj Is Nothing Then Set ssetObj = ThisDrawing.SelectionSets.Add("SSET") End If Dim FilterType As Integer Dim FilterData As Variant FilterType = 67 FilterData = 0 ssetObj.Select acSelectionSetAll, , , FilterType, FilterData
Dim ents() As AcadEntity
Dim i As Inetger
For Each ent in ssetObj
ReDim Preserve ents(i)
Set ents(i)=ent
i = i + 1
Next
SelectAll = ents End Function
 HTH
Norman Yuan
Drive CAD With Code
Message 23 of 28
here are some little modifications to your proposal:
Option Explicit
    ThisDrawing.SelectionSets.Add ("SSET")
    On Error GoTo 0
    With ThisDrawing.SelectionSets("SSET")
        .Clear
        Dim FilterType(0 To 0) As Integer
        Dim FilterData(0 To 0) As Variant
        FilterType(0) = 67
        FilterData(0) = 0
        ReDim ents(0 To .Count - 1)
        Dim i As Integer
        For i = 0 To .Count - 1
            Set ents(i) = .Item(i)
        Next
    End With
    SelectAll = ents
End Function
Message 24 of 28
Hi Norman. Thanks for all your advice. It's good to have the explanations to go with everything - really helps me get my head around it all and how it thinks.
I didn't think I needed to declare ThisDrawing either, but if I don't I keep getting "variable not defined"! I spent ages trying to figure it out and declaring it as i have seems to be the only way to pass it through.
Message 25 of 28
Ed__Jobe
Declaring ThisDrawing and AcadApplication is something that AutoCAD VBA does for you automatically. If you're using COM in another app, i.e. not in AutoCAD, then you have to manually dim ThisDrawing or any other document variable you wish to use.
Another thing that AutoCAD VBA does for you is reference the correct/current AutoCAD tlb. Again, if you are in another app's vba, you have to reference the tlb manually.
Ed
How to post your code.
Message 26 of 28
Ok, sorry I misunderstood you. I am using excel VBA so that is why I need to declare it i guess.
Message 27 of 28
I started by using your code to try and perform the copying functions after selecting all of the items from another sheet. I also added a reference from the autodesk knowledge market "About copying multiple objects" to try and see if by setting an array equal to each copied object, it would actually perform the entire operation. However, it still does not perform as intended. Below is the code in question. I know it is not good practice to make a function for the select all but I think that this condenses everything neatly and should still perform as intended.
The error code I get is a run time error with an "object not in database" description
On Error GoTo 0
ThisDrawing.SelectionSets("SSET").Clear
FilterType(0) = 67
FilterData(0) = 0
ThisDrawing.SelectionSets("SSET").Select acSelectionSetAll, , , FilterType, FilterData
ReDim ents(0 To ThisDrawing.SelectionSets("SSET").Count - 1) As Object
Dim i As Integer
For i = 0 To ThisDrawing.SelectionSets("SSET").Count - 1
Set ents(i) = ThisDrawing.SelectionSets("SSET").Item(i)
Next
Dim newDwgMSpace As AcadModelSpace
Set newDwg = Documents.Add()
Set newDwgMSpace = newDwg.ModelSpace
Dim m As Integer
Dim copiedobjects As Variant
copiedobjects = curDwg.CopyObjects(ents, newDwgMSpace)
Message 28 of 28
I don't see where is curdwg defined and set in your code: you should post all your not working code
