Copy Pasting object from one drawing file to another
Message 1 of 28
Hallo everyone!
I have a problem regarding Autocad drawing with VBA coding. I am trying to copy paste an object (for ex. a circle) from one dwg file to another dwg file via VBA coding. I cant write the code for it. Is there any way to do it besides Wblock command specially when I want to copy paste objects from multiple dwg files?
Please help me...
Replies (27)
Message 2 of 28
norman.yuan
AcadDocument.CopyObjects() method can be used to copy an array of entities to the same drawing, or another drawing that is opened in AutoCAD.
Here is a brief sample VBA code to do what you want:
Option Explicit
Public Sub CopyEntities()
    ''Set the source drawing
    Dim curDwg As AcadDocument
    Dim d As AcadDocument
    For Each d In Application.Documents
        If UCase(d.Name) = "DRAWING1.DWG" Then
            Set curDwg = d
            Exit For
    Next
    If curDwg Is Nothing Then
        MsgBox "Cannot find source drawing ""Drawing1.dwg"""
        Exit Sub
    ''Draw something in the source drawing
    Dim entities() As Object
    entities = DrawSomethings(curDwg)
    MsgBox "Entities count=" & UBound(entities) + 1
    ''Open a new drawing
    Dim newDwg As AcadDocument
    Set newDwg = Application.Documents.Add()
    ''Copy entities from source drawing to new drawing
    curDwg.CopyObjects entities, newDwg.ModelSpace
End Sub
Private Function DrawSomethings(dwg As AcadDocument) As Object()
    Dim ents() As Object
    ReDim ents(4)
    Dim ent As AcadEntity
    Dim i As Integer
    For i = 1 To 5
        Set ent = DrawCircle(dwg, i)
        ent.Update
        Set ents(i - 1) = ent
    Next
    DrawSomethings = ents
End Function
Private Function DrawCircle(dwg As AcadDocument, i As Integer) As AcadEntity
    Dim centre(0 To 2) As Double
    centre(0) = CDbl(i + i): centre(1) = CDbl(i + i): centre(2) = 0#
    Dim radius As Double
    radius = CDbl(i * 5)
    Set DrawCircle = dwg.ModelSpace.AddCircle(centre, radius)
End Function
Norman Yuan
Drive CAD With Code
Message 3 of 28
What if you wanted to copy content from the current drawing, to the model space of another drawing already opened?
Message 4 of 28
Ed__Jobe
Don't let the names curDwg and newDwg confuse you. Think of it as SourceDwg and DestinationDwg. The CopyFrom method is always from the perspective of the Destination dwg. You run the method from the Destination and tell it what Source to CopyFrom.
    DestinationDwg.CopyObjects entities, SourceDwg.ModelSpace
You just have to set DestinationDwg equal to the other dwg to want to copy to, and the SourceDwg equal to ThisDrawing.
Ed
How to post your code.
Message 5 of 28
Ohhh ok, got ya! Thanks.
How come I cant get past the "For Each d In Application.Documents" line?
Says the object doesn't support this method or property...
Message 6 of 28
Ed__Jobe
If you've made changes, show your code.
Ed
Message 7 of 28
I haven't made any changes 😕  Is there a particular reference that needs to be ticked in order to run this??
Message 8 of 28
Ed__Jobe
Yes, "AutoCAD 20## Type Library" should be marked, but vba does that by default. You might have a typo in your code. Norman's works fine for me.
Ed
Message 9 of 28
****. Ok I had that one already selected. I'll have another fiddle today and see how i go. Thanks for your help.
Message 10 of 28
Sorry, I gave it a good couple of weeks of coming back to, looking up alternative codes, incorporating parts from similar codes that are accessing CAD through VBA as well.. and it still won't seem to work for me.
I've copied it word for word - so no spelling mistakes. "AutoCAD 2017 Type Library" is ticked.
But still; "Object doesn't support this property or method".
What on earth could be missing??
Message 11 of 28
Ed__Jobe
It's possible that  your project may have an ambiguity on "application". Try changing the following line to:
For Each d In AcadApplication.Documents
Ed
Message 12 of 28
assuming upama333 is coding from within AutoCAD, he could also simply go:
For Each d In Documents
since Documents is a property of Application object, which would be implicitly resolved
Message 13 of 28
Ed__Jobe
@Anonymous The problem seems to be implicit resolution. Norman's original code should have worked also. But its not working for the OP. What may be happening is that his project references more than one library which has a "application" object and the other library's application object doesn't have a Documents collection. Explicitly specifying AcadApplication should resolve the ambiguity.
@Anonymous Can you post a screen capture of what your References dialog looks like?
Ed
Message 14 of 28
Being in AutoCAD VBA and should there be another reference to a class with another Application object, wouldn't it be taken AutoCAD one for implicit resolution ?
Message 15 of 28
Ed__Jobe
Apparently their system is not able to resolve the reference properly. Implicit references only work when there's no ambiguity. If there is a problem with scope, etc. you need to be explicit. Normally, there wouldn't be another conflicting reference, but its possible. Who knows what they did. That's why I asked for a screen shot. I tested Norman's code as is and it works, so they've done something out of the ordinary to break it.
Ed
Message 16 of 28
This did it!!
There was one other instance in which I had to change the line to "AcadApplication.Documents" as well, and then it worked perfectly. Thank you so much, you put me out of my misery!
Message 17 of 28
I've been trying to find a way to replace the 'entities' with 'all content from model space'.
I've stripped it back a bit - I don't need to draw anything. Is there a VBA equivalent to ssget _"X" ??
Option Explicit
            Set curDwg = d
            Exit For
    Next
        Exit Sub
    Set newDwg = AcadApplication.Documents.Add()
 curDwg.CopyObjects(ALL FROM MODEL SPACE), newDwg.ModelSpace
End Sub
Message 18 of 28
Ed__Jobe
Yes you can select all. Look in the help under SelectionSet.Select. Use the acselectionsetAll mode.
Ed
Message 19 of 28
I have tried using/editing the code from above to help with what I am trying to do, where I am trying to open up another document, copy all of its entities into the document I am currently working in and then close the other document. However, I keep getting a runtime error (438) saying that "object doesn't support this property or method". It keeps on getting stuck in the "copied" line. I know I have not closed the document being copied yet. That will come after this works.
Any thoughts?
Message 20 of 28
Ed__Jobe
You can't use the CopyObjects method that way. You have to pay attention to the method's signature and what type of argument it expects. The Select method doesn't return anything. It just fills a selectionset object (look at the help topic I gave you) and look at help for what arguments the CopyObjects method takes. They have to match.
The Selectionsets object doesn't have a Select method. Dim and instantiate a selectionset, use its Select method. Iterate the selectionset's items and copy them to an object array and then use that as an argument to the CopyObjects method. Use the samples in Help for guidance.
Ed
