End Execution error
End Execution error
Jedimaster
Message 1 of 8
End Execution error
Jedimaster
Sub Test()
End
End Sub
Simple enough subroutine. When I run though debugger no problem. When I exicute it runs but always shows "Execution error". I know that it is because ending before the end of sub.
Thanks for any input.
Replies (7)
Message 2 of 8
norman.yuan
Simple enough, but bad code. The error message is expected.
If you really want to try simplest code to prove your VBA code runs, you can
Sub Test()
End Sub
Which, of course does nothing, but it runs!
"End" keyword is inherited from original BASIC language. "End" means unconditionally ends the code execution without taking care any potential environment issues. In "Visual" Basic era, one should never use "END". Something unexpected could happen, as you have seen from your simple code.
Norman Yuan
Drive CAD With Code
Message 3 of 8
Jedimaster
What this is and END statement at the end of the routine to escape macro no mater what. If I use an END SUB the sub stops but the routine keeps on going. The users freak out because they think the routine has crashed. If the END statement is anywhre before the END SUB the error pops up. It does not show up in debugger just when you are running the macro free standing
Sub Test()
Ask = MsgBox("Are you sure you want to go.", vbYesNo, "Leaving")
If Ask = vbYes Then
End
If Ask = vbNo Then
MsgBox "Glad to see you stay."
End Sub
Message 4 of 8
maybe I'm missing some pieces but why can't you code like this
Sub Test()
    If Ask = vbYes Then Exit Sub
End Sub
Message 5 of 8
norman.yuan
To make it simple:
Where you use "End", you should use "Exit Sub" to exit the subroutine if the condition leads to early finish the subroutine. NEVER EVER use "END". If you claim you have to use it, or the rouine keeps going, then your code is wrong. You'd better fix your code, instead of using "END" to kill the entire VBA routine with "collateral damages", as you have been experienced.
Norman Yuan
Drive CAD With Code
Message 6 of 8
Jedimaster
Have to have hard END to stop whole Function. WScript.Quit in scripting or (exit) in AutoLisp. The sub is a nested sub, being invoked from other subs. The END command works, it is just that outside of the debugger is comes back with the "Exeicution Error".
Message 7 of 8
Never had such a need so I can't say how to properly handle an "end" instruction
but following your need to stop a main sub or function from within a nested one I could suggest a technique as follows
Sub main()
'this is the main external sub you're starting from, calling nested function
'do your stuff
'at some point you'll have a check like this
If Not functionOne(myInt, myObject, ...) Then ' functionOne is the first nested Function
Exit Sub End If End Sub Function functionOne(myInt As Integer, myObject As Object, ...) As Boolean functionOne = True 'do your stuff 'at some point you'll have a check like this If Not functionTwo(myDouble, myLong,...) Then ' functionTwo is the second nested Function functionOne = False Exit Function End If 'go on with your function End Function Function functionTwo(myDouble As Double, myLong As Long,...) As Boolean functionTwo = True 'do your stuff 'at some point you'll have a check like this If Not functionThree(myString, myObject,...) Then ' functionThree is the last nested Function functionTwo = False Exit Function End If 'go on with your function End Function Function functionThree(myString As String, myObject As Object,...) As Boolean functionThree = True 'do your stuff 'at some point you'll have a check like this If myCondition Then functionThree = False Exit Function End If 'go on with your function End Function
where each function parameters list is just an example, showing you don't have to pass the same parameters between functions
this way is safe and gives the result of stopping the entire process virtuallly in any nested function
you could also use nested subs in a similar way but with the following changes:
- pass the same boolean parameter from the main Sub down to each nested Sub that will set it to False or True
- have a check of this boolean parameter right after each nested sub call. on a negative result you'll have to Exit Sub
hope that helps
bye
Message 8 of 8
Jedimaster
I found the problem with the using the "Exit Sub" it was the variable that I was using to escape with was not global so was not passing on to the other subs so I was not true escaping the loop. I have no need for a hard "END" now, although it would be nice to have a simple graceful exit to an entire routine if required.
