check for empty entity in an Array of Entities
I would like to check for a array of Acadline, if a perticular row , column is empty or not.
Dim aline(0 to 10, 0 to 10) as AcadLine
like if i want to check if aline(i,j) is empty or not, how do i check.
not sure I'm answering properly your needs
you could set a dummy acadline variable to aline(i,j) and check whether the former is nothing or not
    On Error Resume Next
    Set alineTemp = aline(0, 0)
    On Error GoTo 0
    If alineTemp Is Nothing Then
    Else
    End If
not even sure the "On Error..." statements must be used: I put them there just to prevent code stopping should any error be risen by the "set" statement
norman.yuan
In classical VB/VBA, a variable is always initialzed upon its declaration. A variable referred to an Object would be initialized to Nothing:
So,
Dim obj as Object
means obj is set to Nothing at its declaration
So, if you declare an array of given type, then each of the element of the array is initialized. In your case,
all the 121 elements are initialized to Nothing.
Following code proves this:
Public Sub Test()
    Dim objs(0 To 2) As AcadEntity
    Dim ent As AcadEntity
    Dim i As Integer
    For i = 0 To UBound(objs)
        Set ent = objs(i)
        If ent Is Nothing Then
            MsgBox "Entity " & i & ": NOTHING"
        Else
            ''This line of code would never run
            MsgBox "Entity " & i & ": good"
        End If
    Next
End Sub
Since you may have some code run after the Dim... and some of the elements may get assigned to actual AcadLine objects, so, you simply test the element in interest to see if it is Nothing:
If aline(i,j) Is Nothing Then
    ''Do something
Else
    ''Do something else
End if
Norman Yuan
Drive CAD With Code
