VBA Error on GetEntity
dennis
Advisor Advisor
dennis
I am calling ThisDrawing.Utility.GetEntity to select a line.  I catch the error if the user hits <return> where I prompt "Invalid selection" and then use End to exit out of the program.
Then I get the following message:
Cannot invoke (command) from *error* without prior call to (*push-error-using-command*).
Converting (command) calls to (command-s) is recommended.
Any help to keep this message from appearing would be helpful.
Alfred.NESWADBA
are you starting a VBA macro from a LISP?
>> then use End
"End" is something very hard to terminate a program. I wouldn't do that, I would use something like that following code-snippet which let the function or sub end in a normal way
Public Sub TEST
   On Error Resume Next
   ThisDrawing.Utility.GetEntity ....
   If Err.Number = 0 then
      On Error Goto 0
      'here run your code with the selected line
End Sub
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
