Problem using intersectWith
Hi
please refer the drawing attached. If i use intersectwith for the 2 lines in left, it works,
where as if i use the same with right side 2 lines, it does not. below is the syntax i used.
Sub intersectLine()
Dim ssetObj As AcadSelectionSet
On Error Resume Next
ThisDrawing.SelectionSets("TEST_SSET").Delete
On Error GoTo 0
Set ssetObj = ThisDrawing.SelectionSets.Add("TEST_SSET")
ssetObj.SelectOnScreen
IntPoint = ssetObj.Item(0).IntersectWith(ssetObj.Item(1), acExtendBoth)
MsgBox (UBound(IntPoint))
End Sub
for left set of lines it returns 2, whereas for right set of lines it returns -1.
the 2 lines on right were copied from different files. i cross checked the properties, but could not get a clew.
Need help.
Alfred.NESWADBA
Look with that statement to the right line objects:
(entget (car (entsel)))
And you will get that results:
I have marked the Z-values of startpoints and endpoints of both lines, these lines do not intersect in 3D-space.
Your left objects are all at Z=0.00 and there the intersection works well.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Thank you Alfred.
Believe this is some kind of accuracy error.
so i am converting all Z to zero before i proceed with my program.
Thank you again.
Ed__Jobe
To convert all Z values to zero, try the Express Tools FLATTEN command.
Ed
How to post your code.
