Problems after installing VBA
OceanaPolynom
OceanaPolynom
Hello
I installed VBA on AutoCad Map 2016.  There were no problems installing VBA.  My code worked correctly.  There are now major problems with AutoCad.  Save As now doesn't show a dialog box, but instead shows a lot of options in the AutoCad text window.  The same goes for the Open command.  I am running Win Pro 7 with Service Pack 1 on a 64 bit machine.
Thank you
John
Alfred.NESWADBA
set sysvar FILEDIA to 1
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
OceanaPolynom
Thank you very much, problem solved
John
