Excel's vba works at home but not at work
Hi to all,
I've created a module with Excel's vba were data is copied to drawing in acad.
At home I have a student version of Acad 2014 and it works fine.
When I use the exact copy at work it gives me OLE errors.
Any ideas of how to sort it out?
CODE:
Dim acadApp As AcadApplication
Dim acadDoc As AcadDocument
Dim acadPol As AcadLWPolyline
Dim dblCoordinates() As Double
'Check if AutoCAD is open.
On Error Resume Next
Set acadApp = GetObject(, "AutoCAD.Application")
On Error GoTo 0
'If AutoCAD is not opened create a new instance and make it visible.
If acadApp Is Nothing Then
Set acadApp = New AcadApplication 'PROG STOPS HERE
acadApp.Visible = True
'Check if there is an active drawing.
Set acadDoc = acadApp.ActiveDocument
On Error GoTo 0
'No active drawing found. Create a new one.
If acadDoc Is Nothing Then
Set acadDoc = acadApp.Documents.Add
Regards
Kenneth
Ed__Jobe
After you try to get an app from the ROT using GetObject() and it fails, you should use CreateObject(), not the New keyword.
Ed
How to post your code.
Sorry, but didn't get!
What exactly i have to do. I'm not new to excell vba but totally to acad
Also work's version is LT. Is it maybe the problem?
Ken
Ed__Jobe
Set acadApp = CreateObject(, "AutoCAD.Application")
Yes, LT is the other problem. It doesn't support VBA.
Ed
Hi Ed,
So basically I'm doomed 360. VBA is in excel and not actually in Acad. Will it work if I use your tip?
Ken
Ed__Jobe
No. Even if you successfully set acadapp, you won't be able to execute the rest of your code. LT doesn't do lisp or vba. No way around it. Like you said, doomed 360. Sorry.
Ed
