Can't Reset Layout Limits - VBA
I'm having trouble resetting the limits of a layout created in VBA. I know you can't set the limits unless the margins and background are turned off but even when I turn them off...
ACADPref.LayoutDisplayMargins = False
ACADPref.LayoutDisplayPaper = False
and reset them...
NewLimits(0) = -17
NewLimits(1) = -5.01
NewLimits(2) = 896.81
NewLimits(3) = 569.96
ThisDrawing.Limits = NewLimits
the layout remains the wrong size.
Ed__Jobe
These are determined by the sheet size of your Layout and the printer driver you are using. In the old days you could do this. I think you can only do that for modelspace limits.
Ed
How to post your code.
You're right Ed. When I run this code, the model space limits change. I've narrowed it down to changing the current layout configuration name. CurrLayout.ConfigName="FileName.PC3" but now I'm having problems with the units (mm vs. in)!
From the online help for PaperUnits property :
"This property determines the units for the display of the layout or plot
configuration in the user interface. This property does not determine the
units for input or query of the ActiveX Automation properties. All ActiveX
Automation properties are represented in millimeters or radians, regardless
of the units settings."
