Select color by DCL
Select color by DCL
Select color by DCL
Hi!
I need can choose one color by DCL.
Is possible call from VB to standard Autocad color DCL ?
Ed__Jobe
Odd...We havn't had that request for a long time. Now you're about the third person to ask that this week. Look for a thread a couple of days ago called "Color selection".
Ed
How to post your code.
Than you and sorry by apologizes,
Odd...We
selection".
I was probing, and it works in VBA, but not in
VB. I need run it from VB, a
ny idea?
thanks
Odd...We
selection".
if this code does not work, make sure windows can find the acad.exe, I would guess that is the problem
Option Explicit
Private Declare Function acedSetColorDialog Lib _
"acad.exe" (color As Long, ByVal bAllowMetaColor _
As Boolean, ByVal nCurLayerColor As Long) As Boolean
Public Function ChooseColor(ByVal lngInitClr As Long, ByVal blnMetaColor As
Boolean, _
ByVal lngCurClr As Long) As Long
ChooseColor = -1
On Error Resume Next
If acedSetColorDialog(lngInitClr, blnMetaColor, lngCurClr) Then
ChooseColor = lngInitClr
On Error GoTo 0
End Function
Sub test_sub()
Dim lColor As Long
Dim R As Long, G As Long, B As Long
lColor = ChooseColor(lColor, True, lColor)
End Sub
"Manuel Pérez Lantarón"
|>Hi!
|>Thanks
James Maeding
Civil Engineer/Programmer
Ed__Jobe
Here's one I wrote that uses vlax.cls from www.acadx.com.
Public Function AcadColorDialog() As Integer
'calls the acad color dialog and returns
'the index of the color selected or -1 if cancelled
Dim i As Integer
Dim VL As New VLAX
'call color dialog
VL.EvalLispExpression ("(setq clr (acad_colordlg 1))")
'if dialog was canceled, clr will be nil, set to -1 instead
i = VL.EvalLispExpression("(if (= clr nil)(setq clr -1)(setq clr clr))")
AcadColorDialog = i
Set VL = Nothing
End Function
If you don't want to use that class, you could modify this sub that I used SendCommand to execute the lisp and stores the color number in USERI1 and then retrieve it with GetVariable. With this function, if the user cancels the color dialog, -1 is returned. With the previous function, the color returned is the same as the argument supplied to the function. It remains unchanged.
Ed
