Block Path
Block Path
Block Path
I am trying to edit the xref path in a DWG files.
dbxDoc.Open @"D:\AutoCad_Registered\FilesDWG\Hummer.DWG",Type.Missing);
foreach(AcadBlock Block in dbxDoc.Blocks)
if(Block.IsXRef)
Cosnole.WriteLine(Block.Name)
With ObjectDBX, the Block has not a property named "Path" , do you from which object i can access this property ?
thanks in advance,
Nicolas
Here is the VBA code I use to get the paths from xrefs
Dim objFileDependencies As AcadFileDependency
For Each objFileDependencies In ThisDrawing.FileDependencies
If objFileDependencies.Feature = "Acad:XRef" Or
objFileDependencies.Feature = "Acad:Image" Then
fgSource = objFileDependencies.FullFileName
fgDestination = TxtDistinationFolder & "\" &
objFileDependencies.FileName
FileCopy fgSource, fgDestination
End If
Next
Hope this helps
Bill.
wrote in message news:4875149@discussion.autodesk.com...
if(Block.IsXRef)
thanks in advance,
Nicolas
Thanks four your help Bill,
I managed to set to set the path of my XREF.
Thanks.
Nicolas
