Setting all entities to bylayer
Message 1 of 17
I would like my macro to change all entities colour, lineweight and linestyle to bylayer.
I tried using SendCommand with "CHANGE" etc. but if it considers no entities can have their properties changed (which does happen) it then fails.
So i assume I must make a selection set of all entities or something and iterate each one? Please clarifiy. Snippet of code if possible?
Thanks.
Andrew
Replies (16)
Message 2 of 17
Please try this code:
Dim ENTITY_NO As Integer
Dim i As Integer
For i = 0 To ENTITY_NO - 1
ThisDrawing.ModelSpace.Item(i).Linetype = "bylayer"
ThisDrawing.ModelSpace.Item(i).Lineweight = acLnWtByLayer
ThisDrawing.ModelSpace.Item(i).color = acByLayer
Next i
Message 3 of 17
You have not stated what teh value of ENTITY_NO should be for the for loop???
Message 4 of 17
You are right. there was a little mistake, the correct code is as below:
Dim i As Integer
ENTITY_NO = ThisDrawing.ModelSpace.Count
Next i
Message 5 of 17
Thanks, this works fine!
Now I have to work out how to change this code:
Call ThisDrawing.SendCommand("UCS WORLD ")
Call ThisDrawing.SendCommand("PLAN WORLD ")
Into non-SendCommand style. Can you help me?
Message 6 of 17
Although this is not the way I would go about it, there are a couple of
things that need to pointed out.
First, you don't need to use a variable to hold the entity count since it is
already being held in the the Count property.
Second, since there could be more than 32768 entities in model space you
should set the data type of your Index variable to Long.
wrote in message news:4875215@discussion.autodesk.com...
Dim i As Integer
Next i
Message 7 of 17
According to the help, the count property is of type integer..
Message 8 of 17
You say you would not do it this way, so why don't you offer you way?
Message 9 of 17
According to help the For statement uses a counter as a numeric variable. The start and end elements are values of the counter (numeric)...not integer or long specific.
The help you have given instructed you to change:
For I = 0 To Entity_No - 1
To
For I = 0 To ThisDrawing.ModelSpace.Count - 1
Message 10 of 17
What I was saying is:
the count property is INTEGER in the autocad help. i was not referring to the for loop syntax..
is it wise to have umpteen repreated calls to two objects "thisdrawing" and "modelspace" just to get to the count property? if i were coding in visual c++ using com, i would have to do two com attaches.
it is common practice to store a value so that it can be directly accessed.
Message 11 of 17
For a suitable definition of integer, that is correct. It's a 32-bit integer.
The VBA For statement evaluates the upper limit for its index just once. If you don't need that value for something else, it is useless to store it in a variable.
Message 12 of 17
OK, here is my code then:
' Sets the line weight, style and colour to bylayer
Public Sub ChangeToBylayer()
Dim iEntity As Long
For iEntity = 0 To ThisDrawing.ModelSpace.Count - 1
With ThisDrawing.ModelSpace.Item(iEntity)
.color = acByLayer
End With
Next iEntity
End Sub
Andrew
Message 13 of 17
Do you have anything in PaperSpace? Any Blocks?
[pre]
Dim Block As AcadBlock
Dim Entity As AcadEntity
For Each Entity In ThisDrawing.ModelSpace
Entity.Linetype = "ByLayer"
Entity.Lineweight = acLnWtByLayer
Entity.Color = acByLayer
Next Entity
For Each Entity In ThisDrawing.PaperSpace
Next Entity
For Each Block In ThisDrawing.Blocks
For Each Entity In Block
Next Entity
Next Block
End Sub
[/pre]
Message 14 of 17
In my situation, the data set is expected to be in modelspace. If there are entities in paperspace it is a non-conformance.
Concerning the type of data in the file, they are polylines, points etc. No blocks. Infact, an earlier part of my macro converts all blocks to points by using an external command.
So this should be OK now.
I have two outstanding issues now:
1. I would like to know how to set the UCS to the WCS and do a plan (at the moment I use two SendCommands to do it).
2. I would like to put the content of a script into the macro. This script assigns the colors for quite a few layers, including line styles. I am not sure of the easiest way to do it.
Message 15 of 17
1. Using SendCommand is the only way I know of to set the WCS.
2. Try something similar to this...
[pre]
Public Sub SetUpLayers()
Dim Layer As AcadLayer
For Each Layer In ThisDrawing.Layers
If Layer.Name Like "DIM*" Then
Layer.Linetype = "HIDDEN"
Next Layer
End Sub
[/pre]
Message 16 of 17
Does this do what you want?
[code]
Public Sub test()
Dim origin(0 To 2) As Double
Dim xAxis(0 To 2) As Double: xAxis(0) = 1
Dim yAxis(0 To 2) As Double: yAxis(1) = 1
Dim ucsFollow As Long
ucsFollow = ThisDrawing.GetVariable("UCSFOLLOW")
ThisDrawing.SetVariable "UCSFOLLOW", 1
ThisDrawing.ActiveUCS = ThisDrawing.UserCoordinateSystems.Add(origin, xAxis, yAxis, "World")
ThisDrawing.SetVariable "UCSFOLLOW", ucsFollow
End Sub
[/code]
Message 17 of 17
this one works best, it delves deeply into all the block entities as well, thank you!!
does anybody know how to get the attribute text to show up right without having to go thru the block attribute manager, all my text still shows up as not bylayer B(
