Password to protect blocks
Message 1 of 8
I have sent this question to other discussion also,but can anyone give me a
solution or some codes that can protect Blocks of being edited or copied ?
A.K.
Replies (7)
Message 2 of 8
If it's for use in your own office, and you can be sure that the VBA code
will be loaded and enabled ...
Here's a hack solution that may provide some protection.
Hope it helps.
Gary
Private Sub AcadDocument_EndCommand(ByVal CommandName As String)
Dim oEntity As AcadEntity
For Each oEntity In ThisDrawing.ActiveSelectionSet
If oEntity.ObjectName = "AcDbBlockReference" Then
SendKeys "UNDO" & vbCrLf
Next
End Sub
Private Sub AcadDocument_SelectionChanged()
For Each oEntity In ThisDrawing.PickfirstSelectionSet
SendKeys Chr(27) & Chr(27)
Next
End Sub
Message 3 of 8
Gary, Thanks for reply
But could you tell me how it works ? I am not professional with VBA.
Thank you.
A.K.
"Gary McMaster" wrote in message
news:4877367@discussion.autodesk.com...
Hope it helps.
Gary
Next
End Sub
Next
End Sub
Message 4 of 8
It uses two of several events built into Acad VBA.
The code in the "EndCommand" event checks each entity in the selection set.
If any of them are blocks it sends an "undo" command.
The code in "SelectionChanged" event checks to see if any blocks are
selected. If so, it sends two escape characters to cancel the command.
Not a great way to do things but ...
To try it:
Type "VBAMAN" at the command line
Select the "Visual Basic Editor" button
Double click on "ThisDrawing" in the Project window
Copy and paste the code in the "Declarations" window
Gary
"A-Design" wrote in message
news:4881381@discussion.autodesk.com...
Thank you.
A.K.
Hope it helps.
Gary
Next
End Sub
Next
End Sub
Message 5 of 8
Thank you so much, it is very good,the bad thing is it can not be used on
other computer.
news:4881579@discussion.autodesk.com...
To try it:
Gary
Thank you.
A.K.
Hope it helps.
Gary
Next
End Sub
Next
End Sub
Message 6 of 8
As I mentioned in my original response:
"If it's for use in your own office ..."
You could "Embed" that code in your start model/template. Assuming everyone
in your office uses the same template the code would always be there. There
are also other methods of automatically loading/executing VBA code.
If you embed it, you will probably have to disable the "Macro Virus" warning
dialog on each computer. That could be dangerous if you accept drawings from
outside sources.
Type "vbaman" at the command line. The "Embed" button is in that first
dialog box. Clicking it will cause that code to be saved with the
drawing/template.
Hope that helps,
Gary
Message 7 of 8
Gary thanks for the answer,
As you know on those files contain the macros, when you try to open them
AutoCAD will ask about a permission to run the marcros, in this time if you
cancel it macros wouldn't be run, is there any way that you write your codes
to prevent user cancel this permission (like closeting the file in case of
cancellation) ?
Thanks again.
A.K.
news:4882215@discussion.autodesk.com...
outside sources.
drawing/template.
Hope that helps,
Gary
Message 8 of 8
A.K.
Again, this will only work on computers that you have control over.
Use the VBA Manager ("vbaman" at command line) to save the previously posted
VBA code to a path and filename of your choice. It may be a network drive.
I have Acad 2004. The following may differ if you have something else.
Add the following two lines of lisp to your "acaddoc.lsp" file. If that file
does not exist, create it using "Windows Notepad" or equivalent and save it
in the Acad search path(s). You will have to modify or create the
acaddoc.lsp file on every machine. Of course the path and filename shown
below will have to match your choices.
Spaces in the path or filename will likely cause problems and will require
further modification of the lisp. The double backslashes are NOT a mistake.
(vl-vbaload "C:\\Temp\\Block-Protect.dvb")
(princ)
Gary
