Thanks it's working in my macro but I found another way to make it
Dim objShell
Dim objFolder
Set objShell = CreateObject("Shell.Application")
Set objFolder = objShell.BrowseForFolder(0, "Example", 0,
txtFolder.Value)
If (Not objFolder Is Nothing) Then
txtFolder.Value = objFolder.self.Path
Set objShell = Nothing
Set objFolder = Nothing
escribió en el mensaje news:4874739@discussion.autodesk.com...
Browse For Folder ....
Windows' common dialogs are great if you want the user to select a file, but
what if you want him/her to select a directory?
Call the following function, which relies on Win32's SHBrowseForFolder
function:
Option Explicit
Private Type BrowseInfo
hWndOwner As Long
pIDLRoot As Long
pszDisplayName As Long
lpszTitle As Long
ulFlags As Long
lpfnCallback As Long
lParam As Long
iImage As Long
End Type
Private Const BIF_RETURNONLYFSDIRS = 1
Private Const MAX_PATH = 260
Private Declare Sub CoTaskMemFree Lib "ole32.dll" (ByVal hMem As Long)
Private Declare Function lstrcat Lib "kernel32" Alias "lstrcatA" _
(ByVal lpString1 As String, ByVal lpString2 As String) As Long
Private Declare Function SHBrowseForFolder Lib "shell32" _
(lpbi As BrowseInfo) As Long
Private Declare Function SHGetPathFromIDList Lib "shell32" _
(ByVal pidList As Long, ByVal lpBuffer As String) As Long
Public Function BrowseForFolder(hWndOwner As Long, sPrompt As String) As
String
Dim iNull As Integer
Dim lpIDList As Long
Dim lResult As Long
Dim sPath As String
Dim udtBI As BrowseInfo
With udtBI
.hWndOwner = hWndOwner
.lpszTitle = lstrcat(sPrompt, "")
.ulFlags = BIF_RETURNONLYFSDIRS
End With
lpIDList = SHBrowseForFolder(udtBI)
If lpIDList Then
sPath = String$(MAX_PATH, 0)
lResult = SHGetPathFromIDList(lpIDList, sPath)
Call CoTaskMemFree(lpIDList)
iNull = InStr(sPath, vbNullChar)
If iNull Then
sPath = Left$(sPath, iNull - 1)
BrowseForFolder = sPath
End Function
Good luck,
Bob Coward
CADS, Inc
800-366-0946
bcoward@mindspring.com
