add dinamically the Type Library
Dears,
Is it possible to dinamically configure the Type Library using VBA?
We have several versions installed and everytime a user with different Autocad version will run the VB code, he has to remember to change the Reference.
Some users may not know how to fix it. Is there a way to do it using VBA code?
Thank you
Ed__Jobe
You can search this forum for using VBE. I've posted an example. However, you need to understand how the problem gets created. When you create a vba project, AutoCAD automatically adds a reference to the correct type library. When you open a vba project in a higher version of AutoCAD, the project automatically gets recompiled to the newer version. The only way to protect against this is to keep 2 copies of the dvb, one for the earlier version and one for the newer version. Set the appropriate tlb in each dvb. Then give the correct dvb to each user. Now you don't need to programmatically set references. If the user has multiple versions of AutCAD on the same pc, put the dvb's in separate folders and use Options to properly set the Support File Search Path.
Ed
How to post your code.
Ok I understood, I guess it is not possible using Excel VBA. Right?
