How to position the the text from right reference?
I know how to add text giving the x,y,z position.
But it considers the text start (Left) on the drawing above.
Is it possible to add a text giving the text end position (Right) ?
Ed__Jobe
In VBA, you are very limited to options when adding entities. You have to change entity properties after you create it. If you simply change the justification to Right, then the point you specified at creation will be the right insert point.
Ed
How to post your code.
